Ir para o conteúdo principal
Samsung NP N310 HAA2US RAM Replacement
O que você precisa
  1. Samsung NP N310 HAA2US RAM Replacement, Battery: passo 1, imagem 1 %32 Samsung NP N310 HAA2US RAM Replacement, Battery: passo 1, imagem 2 %32 Samsung NP N310 HAA2US RAM Replacement, Battery: passo 1, imagem 3 %32
    • Make sure the laptop is powered off, and unplugged before removing the battery.
    • Slide the battery switch to the unlock symbol, and the battery will pop up.
    • Remove the battery.
    Pergunte ao FixBot
    Comentar
  2. Samsung NP N310 HAA2US RAM Replacement, RAM: passo 2, imagem 1 %32 Samsung NP N310 HAA2US RAM Replacement, RAM: passo 2, imagem 2 %32 Samsung NP N310 HAA2US RAM Replacement, RAM: passo 2, imagem 3 %32
    • Locate and unscrew the 5mm screw on the small panel on the back that has 'memory' written on it.
    • Pull off the memory panel.
    Pergunte ao FixBot
    Comentar
  3. Samsung NP N310 HAA2US RAM Replacement: passo 3, imagem 1 %32 Samsung NP N310 HAA2US RAM Replacement: passo 3, imagem 2 %32 Samsung NP N310 HAA2US RAM Replacement: passo 3, imagem 3 %32
    • Pull the 2 latches holding the RAM in, away from the RAM stick, and the RAM will pop up.
    • Pull the RAM out of the slot, only touching the edges of the RAM stick
    Pergunte ao FixBot
    Comentar
Conclusão
Uma outra pessoa concluiu este guia.
Amir Afridi
Membro desde: 09/29/16
626 Reputação
Autoria de 6 guias
Equipe
USF Tampa, Team 4-1, Passmore Fall 2016 Membro de USF Tampa, Team 4-1, Passmore Fall 2016
USFT-PASSMORE-F16S4G1
4 Membros
Autoria de 6 guias
1Comentário do guia
I checked out this guide today (11.2022) to upgrade the RAM in my N310 Windows XP laptop that I bought in the summer of 2009 : ) a whooping 2 GB of DDR2 RAM installed to play old games on original hardware... yee haw!
Mick Germ - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 3
Últimos 7 dias: 6
Últimos 30 dias: 31
Ao todo: 643
