Ir para o conteúdo principal
Samsung ML2510 Motor Replacement
O que você precisa
  1. Samsung ML2510 Motor Replacement, Removing Samsung ML2510 Back Panel: passo 1, imagem 1 %32 Samsung ML2510 Motor Replacement, Removing Samsung ML2510 Back Panel: passo 1, imagem 2 %32 Samsung ML2510 Motor Replacement, Removing Samsung ML2510 Back Panel: passo 1, imagem 3 %32
    • Remove the top hinged panel by taking out the pins at the bottom of this panel.
    Pergunte ao FixBot
    Comentar
  2. Samsung ML2510 Motor Replacement: passo 2, imagem 1 %32
    • Using a Phillips #2 screwdriver, remove the four screws on the back of the printer.
    Pergunte ao FixBot
    Comentar
  3. Samsung ML2510 Motor Replacement: passo 3, imagem 1 %32 Samsung ML2510 Motor Replacement: passo 3, imagem 2 %32 Samsung ML2510 Motor Replacement: passo 3, imagem 3 %32
    • Gently lift the top panel while simultaneously pulling off the back panel.
    • Before pulling out the back panel entirely, make sure to remove the rear cooling fan from its slot.
    Pergunte ao FixBot
    Comentar
  4. Samsung ML2510 Motor Replacement, Motor: passo 4, imagem 1 %32 Samsung ML2510 Motor Replacement, Motor: passo 4, imagem 2 %32 Samsung ML2510 Motor Replacement, Motor: passo 4, imagem 3 %32
    • Remove the front panel by gently moving the holes on the panel, one at a time, from the pegs attached to the main body of the printer.
    Pergunte ao FixBot
    Comentar
  5. Samsung ML2510 Motor Replacement: passo 5, imagem 1 %32
    • Use a Phillips #2 screwdriver to remove the two, 1", Phillips, PH#2 screws on the front face of the printer.
    Pergunte ao FixBot
    Comentar
  6. Samsung ML2510 Motor Replacement: passo 6, imagem 1 %32 Samsung ML2510 Motor Replacement: passo 6, imagem 2 %32 Samsung ML2510 Motor Replacement: passo 6, imagem 3 %32
    • Use plastic opening tool to gently lift one side of the top panel from its peg.
    • Repeat the first process for the other side.
    • Lift the top panel from the front of the printer to remove it entirely.
    Pergunte ao FixBot
    Comentar
  7. Samsung ML2510 Motor Replacement: passo 7, imagem 1 %32 Samsung ML2510 Motor Replacement: passo 7, imagem 2 %32 Samsung ML2510 Motor Replacement: passo 7, imagem 3 %32
    • Lift the left side panel up from the raised stops.
    • Gently rotate the panel, as indicated in the picture, to remove the panel entirely.
    Pergunte ao FixBot
    Comentar
  8. Samsung ML2510 Motor Replacement: passo 8, imagem 1 %32 Samsung ML2510 Motor Replacement: passo 8, imagem 2 %32 Samsung ML2510 Motor Replacement: passo 8, imagem 3 %32
    • Use Phillips #2 screwdriver to remove the five, 1", Phillips, PH#2 screws on the side metal panel.
    • Remove the two, 1", Phillips, PH#2 screws on the back of the printer.
    • Flip over the metal panel to reveal the gear mechanism.
    Pergunte ao FixBot
    Comentar
  9. Samsung ML2510 Motor Replacement: passo 9, imagem 1 %32 Samsung ML2510 Motor Replacement: passo 9, imagem 2 %32 Samsung ML2510 Motor Replacement: passo 9, imagem 3 %32
    • Remove the cable attached to the motor.
    • The entire panel can be removed from the rest of the printer.
    • Use a Phillips #2 screwdriver to remove the motor from the panel by removing the two, 1", Phillips, PH#2 screws.
    • Replace the motor and reassemble the printer by following the instructions in reverse order.
    Pergunte ao FixBot
    Comentar
Linha de Chegada
Uma outra pessoa concluiu este guia.
bbaustin
Membro desde: 10/12/11
268 Reputação
Autoria de 6 guias
Equipe
Cal Poly, Team 17-18, Regan Fall 2011 Membro de Cal Poly, Team 17-18, Regan Fall 2011
CPSU-REGAN-F11S17G18
4 Membros
Autoria de 12 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 8
Últimos 30 dias: 55
Ao todo: 5,352
