Ir para o conteúdo principal
Samsung Level Box Mini Battery Replacement
O que você precisa
  1. Samsung Level Box Mini Battery Replacement, Battery: passo 1, imagem 1 %32 Samsung Level Box Mini Battery Replacement, Battery: passo 1, imagem 2 %32
    Ferramenta utilizada neste passo:
    • Using a plastic opening tool, go around the edges of the rubber bottom. Insert the same tool under the edge of the rubber and swivel side to side. Continue moving it forward while peeling the plastic off with the precision tweezers.
    Pergunte ao FixBot
    Comentar
  2. Samsung Level Box Mini Battery Replacement: passo 2, imagem 1 %32
    • Remove the six 4.5 mm Philips #1 screws from the bottom plate using the Screwdriver J00. Take off the bottom plate.
    Pergunte ao FixBot
    Comentar
  3. Samsung Level Box Mini Battery Replacement: passo 3, imagem 1 %32
    • Using the plastic opening tool, remove the batteries from the device.
    Pergunte ao FixBot
    Comentar
Conclusão
To reassemble your device, follow all the instructions in the reverse order. Use adhesive to stick the rubber back onto the bottom of the device.
9 outras pessoas executaram este guia.
dylan weiss
Membro desde: 02/16/17
134 Reputação
Autoria de 1 guia
Equipe
USF Tampa, Team 1-4, Kass Spring 2017 Membro de USF Tampa, Team 1-4, Kass Spring 2017
USFT-KASS-S17S1G4
5 Membros
Autoria de 4 guias
5Comentários do guia
Did all above but still wont switch on..batt are ok and power gets to the battery points…what could be wrong…
dslotman5 - Responder Compartilhar
I want to replace pcb of this device how to find it??
faraz siddiqui - Responder Compartilhar
I want to replace PCB of this device suggest me where to find?
The "parts needed" list has a search for the battery misspelled in "Samsung".
Jim Plosay - Responder Compartilhar
What kind of batterries should get ?
Aldo Eliezer Rivera Sizzo - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 22
Últimos 30 dias: 87
Ao todo: 10,264
