Ir para o conteúdo principal
Samsung L100 Setting Knob Spring
O que você precisa
    1. Samsung L100 Setting Knob Spring, Removing Back Cover: passo 1, imagem 1 %32 Samsung L100 Setting Knob Spring, Removing Back Cover: passo 1, imagem 2 %32 Samsung L100 Setting Knob Spring, Removing Back Cover: passo 1, imagem 3 %32
      • Remove the six external screws from the camera using a Phillips #0 screwdriver.
      • After the screws has been removed, the bottom of the back half of the external case should be loosened from the camera.
      • Be careful, make sure you don't lose the screws.
      Pergunte ao FixBot
      Comentar
    2. Samsung L100 Setting Knob Spring: passo 2, imagem 1 %32 Samsung L100 Setting Knob Spring: passo 2, imagem 2 %32
      • Open the battery cover that's located on the bottom right side of the camera and carefully remove the battery.
      Pergunte ao FixBot
      Comentar
    3. Samsung L100 Setting Knob Spring: passo 3, imagem 1 %32 Samsung L100 Setting Knob Spring: passo 3, imagem 2 %32 Samsung L100 Setting Knob Spring: passo 3, imagem 3 %32
      • Slide your fingernail or a plastic spudger in the groove from the bottom to the top right side of the camera.
      Pergunte ao FixBot
      Comentar
    4. Samsung L100 Setting Knob Spring: passo 4, imagem 1 %32
      • Carefully squeeze the top right corner of the camera and pry off the external cover.
      • If you hear a "cracking" sound. This is normal.
      • Continue to pull the external cover and it will come off cleanly.
      • Be cautious of the flash capacitor. It carries an electrical charge, that may give you an unpleasant shock.
      Pergunte ao FixBot
      Comentar
    5. Samsung L100 Setting Knob Spring: passo 5, imagem 1 %32
      • Carefully pull off the back cover, parts behind the back of the case might fall out.
      Pergunte ao FixBot
      Comentar
    1. Samsung L100 Setting Knob Spring, Flash Circuit Board: passo 6, imagem 1 %32
      • Remove the screws holding the circuit board.
      • After you remove the screws, carefully remove the circuit board.
      Pergunte ao FixBot
      Comentar
    2. Samsung L100 Setting Knob Spring: passo 7, imagem 1 %32 Samsung L100 Setting Knob Spring: passo 7, imagem 2 %32
      • Remove the front cover, it comes off easily.
      • Buttons might fall out when you remove the front cover.
      Pergunte ao FixBot
      Comentar
    3. Samsung L100 Setting Knob Spring: passo 8, imagem 1 %32
      • Face camera towards you.
      • Remove the two screws from circuit board on the left side of the lens.
      Pergunte ao FixBot
      Comentar
    4. Samsung L100 Setting Knob Spring: passo 9, imagem 1 %32
      • Carefully hold up the circuit board, while it's still connected to the camera.
      • Remove all five screws that's on top of the camera.
      Pergunte ao FixBot
      Comentar
    5. Samsung L100 Setting Knob Spring: passo 10, imagem 1 %32 Samsung L100 Setting Knob Spring: passo 10, imagem 2 %32 Samsung L100 Setting Knob Spring: passo 10, imagem 3 %32
      • Carefully push up the top of the circuit board.
      • Pull up flash circuit board from top of camera.
      Pergunte ao FixBot
      Comentar
    1. Samsung L100 Setting Knob Spring, Setting Knob Spring: passo 11, imagem 1 %32
      • Face the bottom of the Flash Circuit board towards you.
      • Remove the one screw that's located on the left side of the lens.
      Pergunte ao FixBot
      Comentar
    2. Samsung L100 Setting Knob Spring: passo 12, imagem 1 %32
      • Take the flash circuit board and turn it over.
      • Remove the plastic setting knob.
      • Make sure to keep copper spring inside of the slot.
      Pergunte ao FixBot
      Comentar
    3. Samsung L100 Setting Knob Spring: passo 13, imagem 1 %32 Samsung L100 Setting Knob Spring: passo 13, imagem 2 %32 Samsung L100 Setting Knob Spring: passo 13, imagem 3 %32
      Ferramenta utilizada neste passo:
      • Take out and replace the Setting Knob Spring with tweezers.
      Pergunte ao FixBot
      Comentar
Conclusão
andyhe
Membro desde: 04/15/10
81 Reputação
Autoria de 1 guia
Equipe
Cal Poly, Team 6-17, Maness Spring 2010 Membro de Cal Poly, Team 6-17, Maness Spring 2010
CPSU-MANESS-S10S6G17
4 Membros
Autoria de 10 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 8
Últimos 30 dias: 34
Ao todo: 3,564
