Ir para o conteúdo principal
Samsung Jack LCD Replacement
O que você precisa
  1. Samsung Jack LCD Replacement, Battery: passo 1, imagem 1 %32
    • Slide the battery cover downwards with pressure focused on the center of the cover.
    • Lift the cover off of the phone.
    Pergunte ao FixBot
    Comentar
  2. Samsung Jack LCD Replacement: passo 2, imagem 1 %32
    • Grasp the bottom left and right corners of the battery and lift it from its housing.
    Pergunte ao FixBot
    Comentar
  3. Samsung Jack LCD Replacement, Rear Case: passo 3, imagem 1 %32
    • Remove the four black 7.30 mm screws surrounding the battery housing using a Phillips #00 Screwdriver.
    Pergunte ao FixBot
    Comentar
  4. Samsung Jack LCD Replacement: passo 4, imagem 1 %32 Samsung Jack LCD Replacement: passo 4, imagem 2 %32 Samsung Jack LCD Replacement: passo 4, imagem 3 %32
    • The rear case is firmly attached to the phone with clips. Do not be afraid to use a little extra force.
    • Insert the Plastic Opening Tool in between the front and rear cases.
    • Pry with the Plastic Opening Tool around all edges of the phone until you free all the clips.
    Pergunte ao FixBot
    Comentar
  5. Samsung Jack LCD Replacement: passo 5, imagem 1 %32
    • Lift the rear case off of the phone.
    Pergunte ao FixBot
    Comentar
  6. Samsung Jack LCD Replacement, Antenna: passo 6, imagem 1 %32
    • Remove the two silver 4.30 mm screws on either side of the antenna using a Phillip's #00 Screwdriver.
    Pergunte ao FixBot
    Comentar
  7. Samsung Jack LCD Replacement: passo 7, imagem 1 %32 Samsung Jack LCD Replacement: passo 7, imagem 2 %32 Samsung Jack LCD Replacement: passo 7, imagem 3 %32
    • There is a wire under the antenna connecting it to the Motherboard. Do not pull off the antenna just yet.
    • Use a spudger to remove the wire connector under the antenna.
    Pergunte ao FixBot
    Comentar
  8. Samsung Jack LCD Replacement, Speaker: passo 8, imagem 1 %32
    • Remove the two black 7.30 mm screws on the top right and left corners of the Motherboard using a Phillips #00 Screwdriver.
    • Remove the silver 4.50 mm screw located below the speaker using a Phillips #00 Screwdriver.
    Pergunte ao FixBot
    Comentar
  9. Samsung Jack LCD Replacement: passo 9, imagem 1 %32 Samsung Jack LCD Replacement: passo 9, imagem 2 %32
    • Use the spudger to detach the speaker ribbon cable.
    Pergunte ao FixBot
    Comentar
  10. Samsung Jack LCD Replacement: passo 10, imagem 1 %32
    • Lift the speaker out of its compartment.
    Pergunte ao FixBot
    Comentar
  11. Samsung Jack LCD Replacement, Motherboard: passo 11, imagem 1 %32
    • Remove the power and volume buttons on the right side of the Motherboard.
    Pergunte ao FixBot
    Comentar
  12. Samsung Jack LCD Replacement: passo 12, imagem 1 %32 Samsung Jack LCD Replacement: passo 12, imagem 2 %32
    • Use a spudger to detach the camera ribbon cable.
    • Lift the camera off of the Motherboard.
    Pergunte ao FixBot
    Comentar
  13. Samsung Jack LCD Replacement: passo 13, imagem 1 %32 Samsung Jack LCD Replacement: passo 13, imagem 2 %32
    • Use a spudger to disconnect the white antenna wire on the bottom right corner of the Motherboard.
    Pergunte ao FixBot
    Comentar
  14. Samsung Jack LCD Replacement: passo 14, imagem 1 %32 Samsung Jack LCD Replacement: passo 14, imagem 2 %32 Samsung Jack LCD Replacement: passo 14, imagem 3 %32
    • Use a Plastic Opening Tool to lift the flaps of the ZIF connectors to release the ribbon cables near the bottom of the Motherboard.
    • Use a spudger to carefully pull the ribbon cables away from the ZIF connectors.
    Pergunte ao FixBot
    Comentar
  15. Samsung Jack LCD Replacement: passo 15, imagem 1 %32 Samsung Jack LCD Replacement: passo 15, imagem 2 %32
    • There is a ribbon cable under the Motherboard connecting it to the LCD. Do not pull off the Motherboard just yet.
    • Insert the Plastic Opening Tool under the upper left corner of the Motherboard to help reveal the ribbon cable.
    • Use a spudger to disconnect the Motherboard ribbon cable.
    Pergunte ao FixBot
    Comentar
  16. Samsung Jack LCD Replacement: passo 16, imagem 1 %32
    • Lift the Motherboard off of the phone.
    Pergunte ao FixBot
    Comentar
  17. Samsung Jack LCD Replacement, LCD: passo 17, imagem 1 %32 Samsung Jack LCD Replacement, LCD: passo 17, imagem 2 %32 Samsung Jack LCD Replacement, LCD: passo 17, imagem 3 %32
    • The LCD frame is firmly attached to the phone with clips. Do not be afraid to use a little extra force.
    • Insert the Plastic Opening Tool between the LCD frame and the front case of the phone.
    • Slide the Plastic Opening Tool around the LCD frame to detach all of the clips.
    Pergunte ao FixBot
    Comentar
  18. Samsung Jack LCD Replacement: passo 18, imagem 1 %32 Samsung Jack LCD Replacement: passo 18, imagem 2 %32
    • Lift up the LCD frame.
    Pergunte ao FixBot
    Comentar
  19. Samsung Jack LCD Replacement: passo 19, imagem 1 %32 Samsung Jack LCD Replacement: passo 19, imagem 2 %32 Samsung Jack LCD Replacement: passo 19, imagem 3 %32
    • There is a hanging ribbon cable connected to the LCD screen that passes through the LCD frame.
    • Insert the spudger under the bottom left corner of the LCD screen.
    • Use the spudger to gently pry the LCD screen out of its frame.
    • Gently remove the screen from the frame.
    Pergunte ao FixBot
    Comentar
Conclusão
Uma outra pessoa concluiu este guia.
Paul Piller
Membro desde: 04/12/11
56 Reputação
Autoria de 5 guias
Equipe
Cal Poly, Team 24-57, Amido Spring 2011 Membro de Cal Poly, Team 24-57, Amido Spring 2011
CPSU-AMIDO-S11S24G57
4 Membros
Autoria de 7 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 12
Últimos 30 dias: 41
Ao todo: 2,231
