Ir para o conteúdo principal
Samsung Instinct Speaker Replacement
O que você precisa
  1. Samsung Instinct Speaker Replacement, Battery: passo 1, imagem 1 %32
    • Apply pressure to the back cover and slide it forward towards the camera.
    • Lift the back cover off the phone.
    Pergunte ao FixBot
    Comentar
  2. Samsung Instinct Speaker Replacement: passo 2, imagem 1 %32
    • Holding the phone firmly, use the notches to grip and lift up the battery.
    Pergunte ao FixBot
    Comentar
  3. Samsung Instinct Speaker Replacement, Back Case: passo 3, imagem 1 %32
    • Remove the four 4.45mm screws at the corners of the phone.
    Pergunte ao FixBot
    Comentar
  4. Samsung Instinct Speaker Replacement: passo 4, imagem 1 %32 Samsung Instinct Speaker Replacement: passo 4, imagem 2 %32
    • Use the plastic opening tool to unhinge the locks around the edges of the phone.
    • Do not worry about the inner components of the phone; they are not connected to this case.
    Pergunte ao FixBot
    Comentar
  5. Samsung Instinct Speaker Replacement: passo 5, imagem 1 %32
    • Lift the casing off of the phone.
    Pergunte ao FixBot
    Comentar
  6. Samsung Instinct Speaker Replacement, Antenna: passo 6, imagem 1 %32
    • With the screws removed, locate the antenna.
    Pergunte ao FixBot
    Comentar
  7. Samsung Instinct Speaker Replacement: passo 7, imagem 1 %32
    • Using a Phillips head screwdriver, remove the 4.50mm screw holding the antenna in place.
    Pergunte ao FixBot
    Comentar
  8. Samsung Instinct Speaker Replacement: passo 8, imagem 1 %32
    • Using the plastic opener tool, squeeze gently on the antenna cable connector and lift to remove the connector from its position.
    Pergunte ao FixBot
    Comentar
  9. Samsung Instinct Speaker Replacement: passo 9, imagem 1 %32
    • Gently lift up on the antenna and remove it from the back of the device.
    Pergunte ao FixBot
    Comentar
  10. Samsung Instinct Speaker Replacement, Front Case: passo 10, imagem 1 %32
    • Remove the two 3.50mm screws connecting the motherboard to the case.
    Pergunte ao FixBot
    Comentar
  11. Samsung Instinct Speaker Replacement: passo 11, imagem 1 %32 Samsung Instinct Speaker Replacement: passo 11, imagem 2 %32 Samsung Instinct Speaker Replacement: passo 11, imagem 3 %32
    • Use the plastic opener tool to detach the three ribbons on the motherboard.
    Pergunte ao FixBot
    Comentar
  12. Samsung Instinct Speaker Replacement: passo 12, imagem 1 %32
    • Lift out the top right ribbon from its slot on the motherboard.
    Pergunte ao FixBot
    Comentar
  13. Samsung Instinct Speaker Replacement: passo 13, imagem 1 %32 Samsung Instinct Speaker Replacement: passo 13, imagem 2 %32
    • Use the plastic opener tool to unhinge the the locks on the side of the motherboard connecting it to the front casing.
    Pergunte ao FixBot
    Comentar
  14. Samsung Instinct Speaker Replacement: passo 14, imagem 1 %32
    • Lift the motherboard away from the front casing.
    Pergunte ao FixBot
    Comentar
  15. Samsung Instinct Speaker Replacement: passo 15, imagem 1 %32
    • After removing lifting up on the motherboard, the front casing and center frame should be separated as shown.
    Pergunte ao FixBot
    Comentar
  16. Samsung Instinct Speaker Replacement, Speaker: passo 16, imagem 1 %32
    Ferramenta utilizada neste passo:
    • Using tweezers to grasp the pins of the speaker, gently lift the speaker up out of its setting in the front case.
    Pergunte ao FixBot
    Comentar
Conclusão
Brayton
Membro desde: 10/12/11
49 Reputação
Autoria de 2 guias
Equipe
Cal Poly, Team 3-13, Regan Fall 2011 Membro de Cal Poly, Team 3-13, Regan Fall 2011
CPSU-REGAN-F11S3G13
4 Membros
Autoria de 16 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 4
Últimos 30 dias: 27
Ao todo: 1,079
