Introdução
Shows how to place LCD screen of the camera via words and pictures. Replacement of LCD screen requires the removal of motherboard.
O que você precisa
To remove the wristband of the device, grab the middle loop and pull the band through.
Ferramenta utilizada neste passo:Tweezers$4.99
Use tweezers to remove the tape.
Use tweezers to grab the wire ribbon, then pull the wire out of connection.
There are 5 Phillips size 00 screws. Remove all 5 screws.
Wire ribbon is attached to the motherboard.
Use tweezers to disconnect the wire as shown. This will loosen the motherboard from the rear case.
Uma outra pessoa concluiu este guia.
