Introdução
Demonstrates how to replace the front case of the camera through pictures and words. Replacement of the rear case requires disassembling battery housing and battery from front case.
O que você precisa
To remove the wristband of the device, grab the middle loop and pull the band through.
Remove the four screws from the battery housing using a Phillips #00 screwdriver.
Ferramenta utilizada neste passo:Tweezers$4.99
Use an iFixit opening tool to pry up the plastic cover.
Use tweezers to remove the wire from the slots.
