Introdução
The user will need to remove the outer case. Then remove the motherboard. After, they will need remove the cover protecting the LCD.
O que você precisa
Remove the 5.00mm screw on the right of the LCD display towards the bottom of the device by using a Phillips #00 screwdriver.
Once inside the device, find the half that contains the motherboard of the device.
Remove the metal plate under the motherboard.
Use a Phillips head #00 screwdriver to remove the eleven 5.00mm screws.
