Introdução
For the user to remove the camera lens of the Samsung HMX-W200, they will first need to remove the components protecting the lens.
O que você precisa
Remove the 5.00mm screw on the right of the LCD display towards the bottom of the device by using a Phillips #00 screwdriver.
Once inside the device, find the half that contains the motherboard of the device.
Ferramenta utilizada neste passo:Tweezers$4.99
Use the precision tweezers, to gently pull and remove the connector connecting lens and motherboard.
