Introdução
The battery is located inside the camera. It will require uninstalling the battery housing, illustrated in the guide below.
O que você precisa
Remove the 5.00mm screw on the right of the LCD display towards the bottom of the device by using a Phillips #00 screwdriver.
Remove the four 4.00mm screws holding the battery brace using a Phillips #00 screwdriver.
Uma outra pessoa concluiu este guia.
