Ir para o conteúdo principal
Samsung HMX-F90 Record Button Replacement
O que você precisa
    1. Samsung HMX-F90 Record Button Replacement, Battery: passo 1, imagem 1 %32 Samsung HMX-F90 Record Button Replacement, Battery: passo 1, imagem 2 %32 Samsung HMX-F90 Record Button Replacement, Battery: passo 1, imagem 3 %32
      • Pull the release tab away from the battery.
      • Slide the battery towards the release tab and then pull the battery away from the camcorder.
      Pergunte ao FixBot
      Comentar
    1. Samsung HMX-F90 Record Button Replacement, Strap Side Outer Casing: passo 2, imagem 1 %32 Samsung HMX-F90 Record Button Replacement, Strap Side Outer Casing: passo 2, imagem 2 %32
      • Rotate the camcorder so that the strap side is facing you.
      • Locate and remove the three 4.5mm Phillips #00 screws around the hand strap.
      Pergunte ao FixBot
      Comentar
    2. Samsung HMX-F90 Record Button Replacement: passo 3, imagem 1 %32 Samsung HMX-F90 Record Button Replacement: passo 3, imagem 2 %32
      • Rotate the camcorder so that the battery slot is facing you.
      • Located in the top left corner of the battery slot, remove the 4.5mm Phillips #00 screw.
      Pergunte ao FixBot
      Comentar
    3. Samsung HMX-F90 Record Button Replacement: passo 4, imagem 1 %32 Samsung HMX-F90 Record Button Replacement: passo 4, imagem 2 %32
      • Rotate the camcorder so you are looking at the bottom of the camcorder.
      • Locate and remove the last three 4.5mm Phillips #00 screws.
      Pergunte ao FixBot
      Comentar
    4. Samsung HMX-F90 Record Button Replacement: passo 5, imagem 1 %32 Samsung HMX-F90 Record Button Replacement: passo 5, imagem 2 %32 Samsung HMX-F90 Record Button Replacement: passo 5, imagem 3 %32
      • With both hands, pull the side strap apart from the rest of the camcorder.
      Pergunte ao FixBot
      Comentar
    1. Samsung HMX-F90 Record Button Replacement, Record Button: passo 6, imagem 1 %32 Samsung HMX-F90 Record Button Replacement, Record Button: passo 6, imagem 2 %32 Samsung HMX-F90 Record Button Replacement, Record Button: passo 6, imagem 3 %32
      Ferramenta utilizada neste passo:
      • Locate plastic clips of the record button.
      • With tweezers squeeze together the two plastic clips and push the button out.
      • Wiggle and pull the record button to remove completely.
      Pergunte ao FixBot
      Comentar
Conclusão
Amir Harb
Membro desde: 09/26/17
705 Reputação
Autoria de 6 guias
Equipe
USF Tampa, Team S13-G1, Boczar Fall 2017 Membro de USF Tampa, Team S13-G1, Boczar Fall 2017
USFT-BOCZAR-F17S13G1
4 Membros
Autoria de 42 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 38
Ao todo: 693
