Ir para o conteúdo principal
Samsung HMX-F90 LCD Screen Replacement
O que você precisa
  1. Samsung HMX-F90 LCD Screen Replacement, LCD Screen: passo 1, imagem 1 %32 Samsung HMX-F90 LCD Screen Replacement, LCD Screen: passo 1, imagem 2 %32
    • Rotate the camcorder so that back is facing you. Then flip open the LCD screen.
    • Locate and remove the 4.5mm Phillips #00 screws in the LCD screen base.
  2. Samsung HMX-F90 LCD Screen Replacement: passo 2, imagem 1 %32 Samsung HMX-F90 LCD Screen Replacement: passo 2, imagem 2 %32
    • Close the LCD screen. Then lift the silver base away from the camcorder.
  3. Samsung HMX-F90 LCD Screen Replacement: passo 3, imagem 1 %32 Samsung HMX-F90 LCD Screen Replacement: passo 3, imagem 2 %32
    • Rotate the camcorder so that it is facing you.
    • Locate and remove the two 4.5mm Phillips #00 screws.
  4. Samsung HMX-F90 LCD Screen Replacement: passo 4, imagem 1 %32 Samsung HMX-F90 LCD Screen Replacement: passo 4, imagem 2 %32 Samsung HMX-F90 LCD Screen Replacement: passo 4, imagem 3 %32
    • Open the LCD screen and rotate it around 90 degrees.
    • Locate the small prying notch and use a prying tool to slowly remove the LCD cover.
  5. Samsung HMX-F90 LCD Screen Replacement: passo 5, imagem 1 %32 Samsung HMX-F90 LCD Screen Replacement: passo 5, imagem 2 %32 Samsung HMX-F90 LCD Screen Replacement: passo 5, imagem 3 %32
    • Locate and remove the two 3.5mm Phillips #00 screws holding the back cover.
  6. Samsung HMX-F90 LCD Screen Replacement: passo 6, imagem 1 %32 Samsung HMX-F90 LCD Screen Replacement: passo 6, imagem 2 %32 Samsung HMX-F90 LCD Screen Replacement: passo 6, imagem 3 %32
    Ferramenta utilizada neste passo:
    • With tweezers gently unclip the silver tab holding the ribbon wire.
    • Gradually feed the ribbon wire through the hole to remove the screen.
Conclusão
Amir Harb
Membro desde: 09/26/17
705 Reputação
Autoria de 6 guias
Equipe
USF Tampa, Team S13-G1, Boczar Fall 2017 Membro de USF Tampa, Team S13-G1, Boczar Fall 2017
USFT-BOCZAR-F17S13G1
Membros da 4
Autoria de 12 guias
Um comentário
How can I buy the LCD??
Mike - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 10
Duração total: 1,254
