Ir para o conteúdo principal
Samsung HD Pro LED Light Ring Replacement
O que você precisa
    1. Samsung HD Pro LED Light Ring Replacement, Casing: passo 1, imagem 1 %32
      • Locate a small opening around the front panel of the camera.
      Pergunte ao FixBot
      Comentar
    2. Samsung HD Pro LED Light Ring Replacement: passo 2, imagem 1 %32
      • Using a plastic opening tool, apply pressure to various points around the camera to pry open the front panel.
      Pergunte ao FixBot
      Comentar
    3. Samsung HD Pro LED Light Ring Replacement: passo 3, imagem 1 %32
      • Remove both of the connecting wires from the motherboard.
      • Be careful to not bend headers or damage the wires.
      Pergunte ao FixBot
      Comentar
    4. Samsung HD Pro LED Light Ring Replacement: passo 4, imagem 1 %32
      • Apply a plastic opening tool to the gray plastic band around the case of the camera. Insert the edge of the spudger between the case of the camera and the gray plastic band.
      Pergunte ao FixBot
      Comentar
    5. Samsung HD Pro LED Light Ring Replacement: passo 5, imagem 1 %32
      • Apply pressure with the plastic opening tool to various areas of the gray plastic band to pry it from the white plastic back of the case.
      Pergunte ao FixBot
      Comentar
    1. Samsung HD Pro LED Light Ring Replacement, LED Light Ring: passo 6, imagem 1 %32
      • Locate the small circuit board surrounding the lens in the removed front portion of the device.
      Pergunte ao FixBot
      Comentar
    2. Samsung HD Pro LED Light Ring Replacement: passo 7, imagem 1 %32
      • Push the four white tabs away from the center of the lens housing while pulling the led ring up near each tab.
      Pergunte ao FixBot
      Comentar
Conclusão
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 26
Ao todo: 828
