Ir para o conteúdo principal
Samsung HD Pro Camera Lens Replacement
O que você precisa
    1. Samsung HD Pro Camera Lens Replacement, Casing: passo 1, imagem 1 %32
      • Locate a small opening around the front panel of the camera.
      Pergunte ao FixBot
      Comentar
    2. Samsung HD Pro Camera Lens Replacement: passo 2, imagem 1 %32
      • Using a plastic opening tool, apply pressure to various points around the camera to pry open the front panel.
      Pergunte ao FixBot
      Comentar
    3. Samsung HD Pro Camera Lens Replacement: passo 3, imagem 1 %32
      • Remove both of the connecting wires from the motherboard.
      • Be careful to not bend headers or damage the wires.
      Pergunte ao FixBot
      Comentar
    4. Samsung HD Pro Camera Lens Replacement: passo 4, imagem 1 %32
      • Apply a plastic opening tool to the gray plastic band around the case of the camera. Insert the edge of the spudger between the case of the camera and the gray plastic band.
      Pergunte ao FixBot
      Comentar
    5. Samsung HD Pro Camera Lens Replacement: passo 5, imagem 1 %32
      • Apply pressure with the plastic opening tool to various areas of the gray plastic band to pry it from the white plastic back of the case.
      Pergunte ao FixBot
      Comentar
    1. Samsung HD Pro Camera Lens Replacement, Camera Lens: passo 6, imagem 1 %32
      • Locate the camera lens and unscrew it with your hands.
      Pergunte ao FixBot
      Comentar
    2. Samsung HD Pro Camera Lens Replacement: passo 7, imagem 1 %32
      • Remove the washers between the lens and motherboard.
      Pergunte ao FixBot
      Comentar
Conclusão
Hunter Wood
Membro desde: 01/18/17
101 Reputação
Autoria de 1 guia
1Comentário do guia
Where do you purchase a new lens?
Gary - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 6
Últimos 30 dias: 23
Ao todo: 1,164
