Ir para o conteúdo principal
Samsung Gravity TXT microSD Card Replacement
O que você precisa
  1. Samsung Gravity TXT microSD Card  Replacement, Battery: passo 1, imagem 1 %32 Samsung Gravity TXT microSD Card  Replacement, Battery: passo 1, imagem 2 %32
    • Pry the back cover off with a plastic opening tool, or your fingernail, in the indentation on the bottom of the device.
    Pergunte ao FixBot
    Comentar
  2. Samsung Gravity TXT microSD Card  Replacement: passo 2, imagem 1 %32
    • Lift the back cover away from the main body of the phone.
    Pergunte ao FixBot
    Comentar
  3. Samsung Gravity TXT microSD Card  Replacement: passo 3, imagem 1 %32
    • Insert your finger in the groove below the battery.
    • Press the battery toward the audio jack while lifting upward and away from the phone.
    • Remember to place the battery back with the copper contacts on the battery lined up with those on the phone.
    Pergunte ao FixBot
    Comentar
  4. Samsung Gravity TXT microSD Card  Replacement, microSD Card: passo 4, imagem 1 %32 Samsung Gravity TXT microSD Card  Replacement, microSD Card: passo 4, imagem 2 %32 Samsung Gravity TXT microSD Card  Replacement, microSD Card: passo 4, imagem 3 %32
    • Using your fingernail, push the microSD card slightly deeper into the slot, until you hear a click.
    • The removal of the battery is not required for this operation; therefore, step 3 can be skipped if just replacing the microSD card.
    • After the click, release the microSD card to allow it to pop out.
    • Remove the microSD card from its slot
    • When placing the microSD card back in the phone, make sure the card clicks in place.
    Pergunte ao FixBot
    Comentar
Conclusão
Equipe
IUPUI, Team 1-1, Renguette SU 2015 Membro de IUPUI, Team 1-1, Renguette SU 2015
IUPUI-RENGUETTE-SU15S1G1
5 Membros
Autoria de 16 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 17
Ao todo: 446
