Ir para o conteúdo principal
Samsung Gear VR USB Connector Replacement
  1. Samsung Gear VR USB Connector Replacement, USB Connector Replacement: passo 1, imagem 1 %32
    • Remove front cover from headset.
    Pergunte ao FixBot
    Comentar
  2. Samsung Gear VR USB Connector Replacement: passo 2, imagem 1 %32
    • Slide the latch to the right to unlock the current connector.
    Pergunte ao FixBot
    Comentar
  3. Samsung Gear VR USB Connector Replacement: passo 3, imagem 1 %32 Samsung Gear VR USB Connector Replacement: passo 3, imagem 2 %32
    • Lift connector clip away from headset and towards you.
    • Slide current connector out and away from headset until it is disconnected from connector clip.
    Pergunte ao FixBot
    Comentar
  4. Samsung Gear VR USB Connector Replacement: passo 4, imagem 1 %32
    • Select which connector fits the port of the device you wish to use with the Samsung Gear VR.
    • The Samsung Gear VR is packaged with connectors for Micro USB and USB-C.
    Pergunte ao FixBot
    Comentar
  5. Samsung Gear VR USB Connector Replacement: passo 5, imagem 1 %32 Samsung Gear VR USB Connector Replacement: passo 5, imagem 2 %32
    • Slide the connector that connects to your device back onto the connector clip until you feel it settle into place.
    • Slide the lock latch to the left to secure the connector into place.
    Pergunte ao FixBot
    Comentar
Conclusão
3 outras pessoas executaram este guia.
Equipe
USF Tampa, Team S4-G6, Eyestone Fall 2017 Membro de USF Tampa, Team S4-G6, Eyestone Fall 2017
USFT-EYESTONE-F17S4G6
4 Membros
Autoria de 7 guias
5Comentários do guia
Hola, quisiera saber donde se consigue esa parte, ni siquiera en samsung lo he logrado
Jose Davinci - Responder Compartilhar
Were do I get the USB c adapter
helenpaul77 - Responder Compartilhar
If you want USB c adapter I can give you…but we have to make exchange because I need micro usb adapter not type c
Molefi Aaron - Responder Compartilhar
I have the micro USB adapter and need type c. Please advise as to how this barter may be executed?
Saleem A. Sheikh - Responder Compartilhar
Where can I get micro USB converter for gear vr not type c
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 22
Últimos 30 dias: 93
Ao todo: 18,142
