Ir para o conteúdo principal
Samsung Gear S Microphone Replacement
O que você precisa
    1. Samsung Gear S Microphone Replacement, Display Assembly: passo 1, imagem 1 %32 Samsung Gear S Microphone Replacement, Display Assembly: passo 1, imagem 2 %32 Samsung Gear S Microphone Replacement, Display Assembly: passo 1, imagem 3 %32
      • Remove the wrist strap by peeling back the rubber starting from one corner of the watch face. Continue peeling the rubber away from the watch face until the strap is completely off.
      Pergunte ao FixBot
      Comentar
    2. Samsung Gear S Microphone Replacement: passo 2, imagem 1 %32 Samsung Gear S Microphone Replacement: passo 2, imagem 2 %32
      • Starting from an edge, wedge a metal spudger in between the screen and the chrome trim ring and pry, lifting the screen outwards.
      • Some force is needed due to adhesive seal.
      Pergunte ao FixBot
      Comentar
    3. Samsung Gear S Microphone Replacement: passo 3, imagem 1 %32
      • Use a plastic opening tool to gently pry upwards on the plastic motherboard assembly.
      Pergunte ao FixBot
      Comentar
    4. Samsung Gear S Microphone Replacement: passo 4, imagem 1 %32
      • Locate the ribbon assembly attaching the display to the motherboard.
      Pergunte ao FixBot
      Comentar
    5. Samsung Gear S Microphone Replacement: passo 5, imagem 1 %32
      • Use a plastic opening tool to detach the glass screen/ LED Display ribbon connector from the motherboard.
      Pergunte ao FixBot
      Comentar
    6. Samsung Gear S Microphone Replacement: passo 6, imagem 1 %32
      • Now the watch should be in three separate pieces.
      Pergunte ao FixBot
      Comentar
    1. Samsung Gear S Microphone Replacement, Microphone: passo 7, imagem 1 %32
      • Locate the microphone on the lower right corner of the plastic motherboard assembly .
      Pergunte ao FixBot
      Comentar
    2. Samsung Gear S Microphone Replacement: passo 8, imagem 1 %32
      • Use the plastic opening tool to lift up the microphone ribbon connector.
      Pergunte ao FixBot
      Comentar
    3. Samsung Gear S Microphone Replacement: passo 9, imagem 1 %32
      • Use the spudger to lift up the white microphone circuit board.
      Pergunte ao FixBot
      Comentar
Conclusão
3 outras pessoas executaram este guia.
Luis Franco
Membro desde: 09/03/15
1.076 Reputação
Autoria de 4 guias
Equipe
USF Tampa, Team 12-1, Blackwell Fall 2015 Membro de USF Tampa, Team 12-1, Blackwell Fall 2015
USFT-BLACKWELL-F15S12G1
4 Membros
Autoria de 5 guias
3Comentários do guia
ok. thanks a lot but one stupid question where can i buy a new microphone?
amir arya - Responder Compartilhar
any chance of posting were to buy a new mic please..
ian stapleton - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 7
Últimos 30 dias: 33
Ao todo: 2,726
