Ir para o conteúdo principal
Samsung Gear S Display Assembly Replacement
O que você precisa
  1. Samsung Gear S Display Assembly Replacement, Display Assembly: passo 1, imagem 1 %32 Samsung Gear S Display Assembly Replacement, Display Assembly: passo 1, imagem 2 %32 Samsung Gear S Display Assembly Replacement, Display Assembly: passo 1, imagem 3 %32
    • Remove the wrist strap by peeling back the rubber starting from one corner of the watch face. Continue peeling the rubber away from the watch face until the strap is completely off.
    Pergunte ao FixBot
    Comentar
  2. Samsung Gear S Display Assembly Replacement: passo 2, imagem 1 %32 Samsung Gear S Display Assembly Replacement: passo 2, imagem 2 %32
    • Starting from an edge, wedge a metal spudger in between the screen and the chrome trim ring and pry, lifting the screen outwards.
    • Some force is needed due to adhesive seal.
    Pergunte ao FixBot
    Comentar
  3. Samsung Gear S Display Assembly Replacement: passo 3, imagem 1 %32
    • Use a plastic opening tool to gently pry upwards on the plastic motherboard assembly.
    Pergunte ao FixBot
    Comentar
  4. Samsung Gear S Display Assembly Replacement: passo 4, imagem 1 %32
    • Locate the ribbon assembly attaching the display to the motherboard.
    Pergunte ao FixBot
    Comentar
  5. Samsung Gear S Display Assembly Replacement: passo 5, imagem 1 %32
    • Use a plastic opening tool to detach the glass screen/ LED Display ribbon connector from the motherboard.
    Pergunte ao FixBot
    Comentar
  6. Samsung Gear S Display Assembly Replacement: passo 6, imagem 1 %32
    • Now the watch should be in three separate pieces.
    Pergunte ao FixBot
    Comentar
Conclusão
To reassemble your device, follow these instructions in reverse order. You will need an adhesive to connect the screen back to the rest of the watch.
19 outras pessoas executaram este guia.
Equipe
USF Tampa, Team 12-1, Blackwell Fall 2015 Membro de USF Tampa, Team 12-1, Blackwell Fall 2015
USFT-BLACKWELL-F15S12G1
4 Membros
Autoria de 5 guias
16Comentários do guia
Where can i get the LCD for Gear S
Kuek See Chuan - Responder Compartilhar
my screen flashing light and show on screen lines
avi mor - Responder Compartilhar
Hi my gear is showing the watch face setting then glitches to the photo setting and is not allowing me to use any other apps?
Mark Measures - Responder Compartilhar
My watch is doing the same thing. Did you get a fix for it?
steve Walks - Responder Compartilhar
There are flashing yellow lights on the screen, could I fix that?
Alex - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 9
Últimos 30 dias: 43
Ao todo: 16,267
