Ir para o conteúdo principal
Samsung Gear Live Battery Replacement
O que você precisa
    1. Samsung Gear Live Battery Replacement, Lay the watch face-down: passo 1, imagem 1 %32
      • Lay the watch face-down on a flat, stable surface.
      Pergunte ao FixBot
      Comentar
    2. Samsung Gear Live Battery Replacement, Remove the holding pin: passo 2, imagem 1 %32
      • Press the watchband down against the work surface.
      • Press the tip of a flathead screwdriver against the edge of the spring-loaded holding pin.
      Pergunte ao FixBot
      Comentar
    3. Samsung Gear Live Battery Replacement, Remove the watchband: passo 3, imagem 1 %32
      • With the spring-loaded pin pressed in, the watch band should release easily.
      • Gently pull the band away from the body of the watch.
      • Repeat steps 2 and 3 for the opposite side.
      Pergunte ao FixBot
      Comentar
    1. Samsung Gear Live Battery Replacement, Locate the four screws: passo 4, imagem 1 %32
      • With the watch laying face-down, locate the four screws. They are located on the back of the watch, at the four corners.
      Pergunte ao FixBot
      Comentar
    2. Samsung Gear Live Battery Replacement, Remove the 4 screws: passo 5, imagem 1 %32
      • Using a Torx-T5 screwdriver, remove each of the four 4mm screws and set them aside.
      Pergunte ao FixBot
      Comentar
    3. Samsung Gear Live Battery Replacement, Pry off the back of the watch.: passo 6, imagem 1 %32
      • Gently work the plastic opening tool under the top edge of the watch’s back cover.
      Pergunte ao FixBot
      Comentar
    4. Samsung Gear Live Battery Replacement, Lift off the back cover: passo 7, imagem 1 %32 Samsung Gear Live Battery Replacement, Lift off the back cover: passo 7, imagem 2 %32
      • With the watch’s back cover pried loose, gently lift it away from the front half of the watch.
      Pergunte ao FixBot
      Comentar
    5. Samsung Gear Live Battery Replacement, Set both halves of the watch aside: passo 8, imagem 1 %32
      • Lay both halves of the watch body assembly face down (with internal components facing up).
      Pergunte ao FixBot
      Comentar
    1. Samsung Gear Live Battery Replacement, Locate the battery: passo 9, imagem 1 %32
      • Locate the battery on the back half of the disassembled watch body. It is rectangular in shape and located just above the window for the heart monitor.
      Pergunte ao FixBot
      Comentar
    2. Samsung Gear Live Battery Replacement, Locate the battery contacts: passo 10, imagem 1 %32
      • Locate the battery’s electrical contacts. They are located next to the heart rate monitor. They roughly form a “+” shape.
      • Using the plastic opening tool, gently pry the contacts away from the plastic channel in which they fit.
      Pergunte ao FixBot
      Comentar
    3. Samsung Gear Live Battery Replacement, Pry out the battery: passo 11, imagem 1 %32
      • Gently work the plastic opening tool under the battery.
      • Using the plastic opening tool, gently pry the battery up.
      • If replacing the battery, please dispose of it properly. Do not throw the battery in the trash. Contact your local municipality for locations which accept lithium-ion batteries for disposal or recycling.
      Pergunte ao FixBot
      Comentar
Conclusão
14 outras pessoas executaram este guia.
Keith Cooper
Membro desde: 09/25/14
1.265 Reputação
Autoria de 6 guias
Equipe
USF Tampa, Team 1-7, Brown Fall 2014 Membro de USF Tampa, Team 1-7, Brown Fall 2014
USFT-BROWN-F14S1G7
3 Membros
Autoria de 7 guias
7Comentários do guia
Indicate the tools needed.
Dan Brown - Responder Compartilhar
Indicate screw measurements to nearest mm.
This is neat and helpful, but where do I find a replacement battery?
joshthehappy - Responder Compartilhar
Where can I purchase these batteries?
chad flores - Responder Compartilhar
I purchased my battery on eBay.
Jay - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 9
Últimos 30 dias: 43
Ao todo: 10,109
