Ir para o conteúdo principal
Samsung Gear Fit Screen Replacement
O que você precisa
  1. Samsung Gear Fit Screen Replacement, Watch Band: passo 1, imagem 1 %32 Samsung Gear Fit Screen Replacement, Watch Band: passo 1, imagem 2 %32
    • Place your thumbs on the ends of the screen.
    • Push the watch outward while pulling the band away from the watch.
  2. Samsung Gear Fit Screen Replacement, Screen: passo 2, imagem 1 %32
    • Heating the device with a hair dryer may warp the screen or damage the device. It it preferable to use an iOpener for this step.
    • For step-by-step instructions on using an iOpener, see the iOpener Instructions.
    • Use a hair dryer, heat gun, or an iOpener to heat the Gear Fit for 1-2 minutes until it is hot to the touch.
  3. Samsung Gear Fit Screen Replacement: passo 3, imagem 1 %32 Samsung Gear Fit Screen Replacement: passo 3, imagem 2 %32 Samsung Gear Fit Screen Replacement: passo 3, imagem 3 %32
    • The screen is connected to the device by a ribbon cable on the left side with the power button facing you. Do not try to completely separate the screen from the device yet, and be careful.
    • Gently pry the screen loose using a plastic opening tool.
    • If the screen doesn't easily come loose, more heating may be required
  4. Samsung Gear Fit Screen Replacement: passo 4, imagem 1 %32 Samsung Gear Fit Screen Replacement: passo 4, imagem 2 %32 Samsung Gear Fit Screen Replacement: passo 4, imagem 3 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • Using tweezers as a lever, pry the inner assembly out of the external casing.
    • This will be harder than removing the screen. Moderate force may be required.
  5. Samsung Gear Fit Screen Replacement: passo 5, imagem 1 %32 Samsung Gear Fit Screen Replacement: passo 5, imagem 2 %32 Samsung Gear Fit Screen Replacement: passo 5, imagem 3 %32
    • Disconnect the ribbon cables connecting the screen to the motherboard by lifting their metal connectors up off of the board with tweezers.
  6. Samsung Gear Fit Screen Replacement: passo 6, imagem 1 %32 Samsung Gear Fit Screen Replacement: passo 6, imagem 2 %32
    • Gently peel the screen assembly up and away from the device using tweezers.
Conclusão
17 outras pessoas executaram este guia.
Nathan Powell
Membro desde: 04/24/14
1.577 Reputação
Autoria de 3 guias
Equipe
Cal Poly, Team 11-49, Amido Spring 2014 Membro de Cal Poly, Team 11-49, Amido Spring 2014
CPSU-AMIDO-S14S11G49
Membros da 4
Autoria de 4 guias
28 comentários
Hi!
Thank you very much for this tuto. But wher can we acquire the screen ???
Thanks a lot.
AB
aaa - Responder
Where can you buy replacement screen?
Yele Olaniyi - Responder
I'm also finding it difficult to buy a replacement screen too. Has anyone discovered some. I thought this website was selling some not too long ago. Any more coming in?
Rochelle - Responder
Hi guys,
is it possible to detach the display unit from the protective plastic cover (I think it's not glass) ?
alexxtodorov - Responder
Does anyone know where to get the replacement screen?
MrGratts - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 10
Últimos 30 dias: 31
Duração total: 53,549
