Esta versão pode conter edições incorretas. Mude para o último instantâneo verificado.
O que você precisa
Este passo não foi traduzido. Ajude a traduzi-lo
Place your thumbs on the ends of the screen.
Push the watch outward while pulling the band away from the watch.
Use a hair dryer, heat gun, or an iOpener to heat the Gear Fit for 1-2 minutes until it is hot to the touch.
Gently pry the screen loose using a plastic opening tool.
Using tweezers as a lever, pry the inner assembly out of the external casing.
This will be harder than removing the screen. Moderate force may be required.
Disconnect the ribbon cables connecting the screen to the motherboard by lifting their metal connectors up off of the board with tweezers.
Gently peel the screen assembly up and away from the device using tweezers.
Three ribbon cables hold the motherboard to the rest of the assembly.
The battery cable in the front.
And two on the side.
Using a pair of tweezers, carefully pull each connector away to disconnect it from the rest of the assembly.
The motherboard is a segmented three piece construction.
Use tweezers to first lift up, with a moderate amount of force, and free each ends of the motherboard from the assembly.
The motherboard should now be removable from the assembly.
Use tweezers to lightly pry, lift, and remove the board by its middle section.
With the motherboard removed, the battery is exposed.
A small metal strut protects the battery.
Remove the small metal strut by prying it out of both sides of the enclosure.
Remove the battery by pulling on the pull tab.
Don't be afraid to use force, the battery is tightly packed into the plastic enclosure.
37 outras pessoas executaram este guia.
9 comentários
Bgdhdhdhxhzjxjchf
Gdkysgkdgkdgxgmzg
Anyone know where I can find replacement parts for the charging terminals? One of the 5 fell out and I can't seem to find this simple piece anywhere.
Where i can purchase a replacement battery in india?
