Ir para o conteúdo principal
Samsung Gear 360 Battery Replacement
  1. Samsung Gear 360 Battery Replacement, Battery: passo 1, imagem 1 %32
    • Insert thumb under tab of battery cover.
    • Pull to remove the battery cover.
    Pergunte ao FixBot
    Comentar
  2. Samsung Gear 360 Battery Replacement: passo 2, imagem 1 %32 Samsung Gear 360 Battery Replacement: passo 2, imagem 2 %32
    • Once the cover is opened, press index finger on the tab to release the battery from the battery slot.
    Pergunte ao FixBot
    Comentar
  3. Samsung Gear 360 Battery Replacement: passo 3, imagem 1 %32
    • Once the battery has popped out, pull the battery out of the camera.
    Pergunte ao FixBot
    Comentar
Conclusão
Angel Veras
Membro desde: 02/20/17
107 Reputação
Autoria de 1 guia
Equipe
USF Tampa, Team S3-G5, Sullivan Spring 2017 Membro de USF Tampa, Team S3-G5, Sullivan Spring 2017
USFT-SULLIVAN-S17S3G5
4 Membros
Autoria de 14 guias
1Comentário do guia
I charged one battery successfully and proceeded to remove the battery and insert another battery to charge. The camera died and would not charge the second battery, so I re-inserted the charged battery and now the camera will not power up. Any ideas?
Mark Newsom - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 3
Últimos 7 dias: 17
Últimos 30 dias: 68
Ao todo: 8,381
