Introdução
If your home button is smashed in, or isn't functioning properly then this guide will show you step-by-step instructions for home button replacement. This is very easy rated at 3 out of 10. and should only take 5 minutes.
O que você precisa
Remove the wristband by sliding the metal pins located on both sides of the wrist band, and pulling the wristband off.
Using the plastic opening tool, pull up on the flex connector. It will come off the motherboard, but will stay attached to the cover like a hinge.
Ferramenta utilizada neste passo:Tweezers$4.99
Using fine tweezers, pull the home button ribbon cable up and away from the front cover.
1Comentário do guia
do you know where i purchase the actual button?
