Ir para o conteúdo principal
Samsung Gear 2 Camera Replacement
O que você precisa
    1. Samsung Gear 2 Camera Replacement, Front half and Back half: passo 1, imagem 1 %32 Samsung Gear 2 Camera Replacement, Front half and Back half: passo 1, imagem 2 %32
      • Before disassembling your Gear, be sure it is powered off.
      • To remove each strap, locate the metal latches on both sides of the back of the Gear.
      • Press down on the metal latch while pulling the strap away from the Gear until it is completely off.
      Pergunte ao FixBot
      Comentar
    2. Samsung Gear 2 Camera Replacement: passo 2, imagem 1 %32
      • Remove the four 4.0 mm screws on the back of the Gear using a T5 Torx Screwdriver.
      Pergunte ao FixBot
      Comentar
    3. Samsung Gear 2 Camera Replacement: passo 3, imagem 1 %32 Samsung Gear 2 Camera Replacement: passo 3, imagem 2 %32 Samsung Gear 2 Camera Replacement: passo 3, imagem 3 %32
      • Firmly holding the Gear, insert the flat side of the spudger at an angle to pry the back casing off of the device. Move the spudger along the sides of the Gear to completely detach the back and front components.
      • Pry the device open from the other side also if it does not fully disassemble from one side.
      Pergunte ao FixBot
      Comentar
    1. Samsung Gear 2 Camera Replacement, Camera: passo 4, imagem 1 %32 Samsung Gear 2 Camera Replacement, Camera: passo 4, imagem 2 %32
      Ferramenta utilizada neste passo:
      • Locate the rectangular metal connector that attaches the camera to the Gear.
      • Use tweezers to gently lift and detach the metal plate of the connector.
      • When reassembling the Gear, reattach the camera connector by carefully aligning the metal plate and its pins to its original placement. Make sure it snaps in place to avoid improper connections and possible damage.
      Pergunte ao FixBot
      Comentar
    2. Samsung Gear 2 Camera Replacement: passo 5, imagem 1 %32
      • Use tweezers to carefully lift the camera from its slot out of the case.
      Pergunte ao FixBot
      Comentar
Conclusão
Allison Michel
Membro desde: 04/14/14
513 Reputação
Autoria de 3 guias
Equipe
Cal Poly, Team 13-27, Maness Spring 2014 Membro de Cal Poly, Team 13-27, Maness Spring 2014
CPSU-MANESS-S14S13G27
4 Membros
Autoria de 6 guias
1Comentário do guia
Hey cool! Were can i buy the camara?
jorge - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 40
Ao todo: 4,122
