Ir para o conteúdo principal
Samsung Gear 2 Battery Replacement
O que você precisa
    1. Samsung Gear 2 Battery Replacement, Front half and Back half: passo 1, imagem 1 %32 Samsung Gear 2 Battery Replacement, Front half and Back half: passo 1, imagem 2 %32
      • Before disassembling your Gear, be sure it is powered off.
      • To remove each strap, locate the metal latches on both sides of the back of the Gear.
      • Press down on the metal latch while pulling the strap away from the Gear until it is completely off.
      Pergunte ao FixBot
      Comentar
    2. Samsung Gear 2 Battery Replacement: passo 2, imagem 1 %32
      • Remove the four 4.0 mm screws on the back of the Gear using a T5 Torx Screwdriver.
      Pergunte ao FixBot
      Comentar
    3. Samsung Gear 2 Battery Replacement: passo 3, imagem 1 %32 Samsung Gear 2 Battery Replacement: passo 3, imagem 2 %32 Samsung Gear 2 Battery Replacement: passo 3, imagem 3 %32
      • Firmly holding the Gear, insert the flat side of the spudger at an angle to pry the back casing off of the device. Move the spudger along the sides of the Gear to completely detach the back and front components.
      • Pry the device open from the other side also if it does not fully disassemble from one side.
      Pergunte ao FixBot
      Comentar
    1. Samsung Gear 2 Battery Replacement, Battery: passo 4, imagem 1 %32 Samsung Gear 2 Battery Replacement, Battery: passo 4, imagem 2 %32
      • Use the pointed side of the spudger to remove the small, orange battery cable.
      Pergunte ao FixBot
      Comentar
    2. Samsung Gear 2 Battery Replacement: passo 5, imagem 1 %32 Samsung Gear 2 Battery Replacement: passo 5, imagem 2 %32
      • Remove the battery by pulling the white tab on the battery marked "PULL."
      • Make sure the orange battery cable is fully disconnected to avoid ripping it off and tearing it.
      Pergunte ao FixBot
      Comentar
Conclusão
26 outras pessoas executaram este guia.
Jonathan Molina
Membro desde: 04/14/14
1.018 Reputação
Autoria de 2 guias
Equipe
Cal Poly, Team 13-27, Maness Spring 2014 Membro de Cal Poly, Team 13-27, Maness Spring 2014
CPSU-MANESS-S14S13G27
4 Membros
Autoria de 6 guias
15Comentários do guia
Where can one find said replacement battery. I had it on in less than a meter of water for less than 30 minutes and water was able to get in. Even though I did not subject it to its supposed limitations I am fairly certain that best buy or samsung will check the water indicator paper and tell me that it was my fault. I have taken it apart and gotten it all dried out. It will come on and function just fine and then when i unplug it it will turn off after a minute or so. At any rate, I would like to replace my battery but need to find one first.
paul - Responder Compartilhar
Where can I find a battery I have looked everywhere including Ebay and Amazon?
Mike Landriault - Responder Compartilhar
I am looking for a battery also mine is very bad after 1 year. Were you able to find one?
Mimo Caceres - Responder Compartilhar
We're can I find a replacement battery for my gear 2 neo watch looked everywhere
Drock - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 7
Últimos 30 dias: 50
Ao todo: 59,430
