Introdução
Use this guide to replace a worn-out or dead battery in your Samsung Galaxy Watch3.
If your battery is swollen, take appropriate precautions. For your safety, discharge your battery below 25% before disassembling your smartwatch. This reduces the risk of a dangerous thermal event if the battery is accidentally damaged during the repair.
You’ll need replacement adhesive to reattach a new battery when reassembling the device.
O que você precisa
Before starting repairs, take your watch off the charger and power it down.
Use a Tri-point Y00 driver to unfasten the four screws on the back of the watch.
Insert an opening tool between the back cover and the metal housing.
Twist the opening tool to create a wider gap.
Lay the watch face down.
Carefully lift the back cover up from the edge with the buttons to access the sensor connector.
Use the flat end of a spudger to pry up and disconnect the sensor flex cable from the motherboard.
Use the flat end of a spudger to disconnect the flex cables of the side buttons, the display and the hall sensor.
The motherboard is held in place by two small plastic clips.
Use a pair of blunt tweezers to lift the motherboard out from underneath the plastic clips towards the buttons.
Remove the motherboard.
Place the flat end of a supdger in the small gap between the plastic frame and the battery, opposite to the display cable.
Carefully lever the battery up and out of its recess.
Ferramenta utilizada nesse passo:Tesa 61395 Tape$5.99
Lift the battery up a little in order to access its glued down connector cable.
Use a pair of blunt tweezers to lift up the battery connector which is secured with some light adhesive.
Remove the battery.
If possible, turn on your device and test your repair before installing new adhesive and resealing.
Secure the new battery with pre-cut adhesive or double-sided adhesive tape. In order to position it correctly, apply the new adhesive into the device at the places where the old adhesive was located, not directly onto the battery.
For optimal performance, calibrate your newly installed battery: Charge it to 100% and keep charging it for at least 2 more hours. Then use your device until it shuts off due to low battery. Finally, charge it uninterrupted to 100%.
18 outras pessoas executaram este guia.
17 comentários
Once I had the correct tools and replacement battery, fixing was easy. Tyvm!
One question, where can I find an authorized battery for this watch? or one that you highly recommend. Thanks.
**Edit - Your store doesn’t have a 45mm battery for my Galaxy Watch 3. Only 42 and 46.
The 42 and 46 mm models are the first Galaxy Watch sizes. We ’re working on getting the Watch3 batteries and parts but it may take some time.
Hi, is it possible to put the battery from samsung watch 472mAh, on samsung watch 3, instead of 340mAh?
Hi Andrey, short answer is no—although basically a good idea. But even if you cut the battery contact plate to fit (cut off the part with the alignment hole) its polarity is inverted. The Watch3 contact plate has -/+ (noted under the cable) whereas the original has +/-. Also the original Galaxy Watch battery is much bigger than the one in the Watch3. So it won’t fit inside the recess. Here is an image with the Watch3 battery on top of the original battery.
