Introdução
Use this guide to replace a worn-out or dead battery in your Galaxy Watch.
If your battery is swollen, take appropriate precautions. For your safety, discharge your battery below 25% before disassembling your smartwatch. This reduces the risk of a dangerous thermal event if the battery is accidentally damaged during the repair.
O que você precisa
Remove the four Tri-point #00 screws (4.2 mm length) on the backside of the watch.
Use a spudger to disconnect the display flex cable from the motherboard.
Push the battery out of its recess through the cutout in the plastic frame.
Remove the battery.
If possible, turn on your device and test your repair before installing new adhesive and resealing.
Secure the new battery with pre-cut adhesive or double-sided adhesive tape. In order to position it correctly, apply the new adhesive into the device at the places where the old adhesive was located, not directly onto the battery.
For optimal performance, calibrate your newly installed battery: Charge it to 100% and keep charging it for at least 2 more hours. Then use your device until it shuts off due to low battery. Finally, charge it uninterrupted to 100%.
117 outras pessoas executaram este guia.
49 comentários
thank you,it really help alot
Where can I buy the battery?
We hope to have them in our store soon. Check on our Samsung smartwatch parts over at [[ invalid parts link ]]
How much does this cost for a battery and labor
