Ir para o conteúdo principal
Samsung Galaxy Watch Battery Replacement
O que você precisa
  1. Samsung Galaxy Watch Battery Replacement, Opening Procedure: passo 1, imagem 1 %32
    • Remove the four Tri-point #00 screws (4.2 mm length) on the backside of the watch.
  2. Samsung Galaxy Watch Battery Replacement: passo 2, imagem 1 %32 Samsung Galaxy Watch Battery Replacement: passo 2, imagem 2 %32
    • Use an opening tool to get between the back cover and the metal housing of the watch.
    • Carefully pry the plastic back cover open.
    • Don't remove the back cover yet. There is a flex cable running to the core assembly inside.
  3. Samsung Galaxy Watch Battery Replacement: passo 3, imagem 1 %32 Samsung Galaxy Watch Battery Replacement: passo 3, imagem 2 %32
    • Lay down the watch and lift the back cover to access the sensor connector on the motherboard.
  4. Samsung Galaxy Watch Battery Replacement: passo 4, imagem 1 %32 Samsung Galaxy Watch Battery Replacement: passo 4, imagem 2 %32
    • Use a spudger to disconnect the sensor flex cable from the motherboard.
  5. Samsung Galaxy Watch Battery Replacement: passo 5, imagem 1 %32 Samsung Galaxy Watch Battery Replacement: passo 5, imagem 2 %32 Samsung Galaxy Watch Battery Replacement: passo 5, imagem 3 %32
    • Remove the back cover.
    • When closing the watch make sure the rubber gasket is undamaged or replace it with a new one.
  6. Samsung Galaxy Watch Battery Replacement, Core Assembly Removal: passo 6, imagem 1 %32 Samsung Galaxy Watch Battery Replacement, Core Assembly Removal: passo 6, imagem 2 %32
    • Use a spudger to disconnect the display flex cable from the motherboard.
  7. Samsung Galaxy Watch Battery Replacement: passo 7, imagem 1 %32 Samsung Galaxy Watch Battery Replacement: passo 7, imagem 2 %32
    • Lift the core unit out of the housing.
    • The core's plastic frame sits tight inside the housing.
    • Carefully thread the display flex cable through the gap of the core's plastic frame.
  8. Samsung Galaxy Watch Battery Replacement, Motherboard: passo 8, imagem 1 %32 Samsung Galaxy Watch Battery Replacement, Motherboard: passo 8, imagem 2 %32
    • Use a spudger to disconnect the hall sensor flex cable.
  9. Samsung Galaxy Watch Battery Replacement: passo 9, imagem 1 %32 Samsung Galaxy Watch Battery Replacement: passo 9, imagem 2 %32 Samsung Galaxy Watch Battery Replacement: passo 9, imagem 3 %32
    Ferramenta utilizada neste passo:
    • Use a pair of tweezers to gently peel both button cables from the plastic frame.
    • The button cables have metal plates behind them. These plates should remain on the cables.
  10. Samsung Galaxy Watch Battery Replacement: passo 10, imagem 1 %32
    • Remove the single Phillips #00 screw (3.4 mm length).
  11. Samsung Galaxy Watch Battery Replacement: passo 11, imagem 1 %32 Samsung Galaxy Watch Battery Replacement: passo 11, imagem 2 %32 Samsung Galaxy Watch Battery Replacement: passo 11, imagem 3 %32
    • Insert a spudger into the small gap underneath the motherboard where the cutout in the plastic frame is.
    • Lift the motherboard by twisting the spudger.
    • Slide the motherboard out from under the plastic tab.
  12. Samsung Galaxy Watch Battery Replacement: passo 12, imagem 1 %32
    • Remove the motherboard.
  13. Samsung Galaxy Watch Battery Replacement, Battery: passo 13, imagem 1 %32 Samsung Galaxy Watch Battery Replacement, Battery: passo 13, imagem 2 %32 Samsung Galaxy Watch Battery Replacement, Battery: passo 13, imagem 3 %32
    • Push the battery out of its recess through the cutout in the plastic frame.
    • The battery cable may slightly stick to the plastic frame—pull carefully.
    • Remove the battery.
Conclusão
If possible, turn on your device and test your repair before installing new adhesive and resealing.
Secure the new battery with pre-cut adhesive or double-sided adhesive tape. In order to position it correctly, apply the new adhesive into the device at the places where the old adhesive was located, not directly onto the battery.
For optimal performance, calibrate your newly installed battery: Charge it to 100% and keep charging it for at least 2 more hours. Then use your device until it shuts off due to low battery. Finally, charge it uninterrupted to 100%.
135 outras pessoas executaram este guia.
Tobias Isakeit
Membro desde: 03/31/14
124.281 Reputação
Autoria de 189 guias
Equipe
55 comentários
thank you,it really help alot
Otunla oluwashina - Responder
Where can I buy the battery?
Buzz Burrows - Responder
Where can you buy the battery 42mm version?
Thomas - Responder
We hope to have them in our store soon. Check on our Samsung smartwatch parts over at https://www.ifixit.com/Store/Parts/Samsu...
Tobias Isakeit -
How much does this cost for a battery and labor
Audrey Snit - Responder
Comentar
Visualizações:
Últimas 24 horas: 101
Últimos 7 dias: 780
Últimos 30 dias: 3,706
Ao todo: 313,776
