Ir para o conteúdo principal
Samsung Galaxy Watch Active2 Motherboard Replacement
O que você precisa
  1. Samsung Galaxy Watch Active2 Motherboard Replacement, Turn off the watch: passo 1, imagem 1 %32 Samsung Galaxy Watch Active2 Motherboard Replacement, Turn off the watch: passo 1, imagem 2 %32
    • Turn off the Galaxy Watch Active2 by pushing and holding the bottom button for approximately 3 seconds. You should feel a short vibration.
    • When the "Power off" symbol appears, tap the center of the screen to make it shut down. You should feel a longer vibration for confirmation.
  2. Samsung Galaxy Watch Active2 Motherboard Replacement, Remove the rear screws: passo 2, imagem 1 %32
    • Use a Tri-point Y00 screwdriver to remove the four 4 mm-long screws on the back of the watch.
  3. Samsung Galaxy Watch Active2 Motherboard Replacement, Separate the back cover from the housing: passo 3, imagem 1 %32 Samsung Galaxy Watch Active2 Motherboard Replacement, Separate the back cover from the housing: passo 3, imagem 2 %32 Samsung Galaxy Watch Active2 Motherboard Replacement, Separate the back cover from the housing: passo 3, imagem 3 %32
    • Use an opening pick and place it between the plastic back cover and the metal housing near the buttons.
    • Push the opening pick into the gap to separate the back cover from the housing.
    • Don’t remove the back cover all the way yet. There is a cable connecting it to the motherboard.
  4. Samsung Galaxy Watch Active2 Motherboard Replacement, Disconnect the sensor array: passo 4, imagem 1 %32 Samsung Galaxy Watch Active2 Motherboard Replacement, Disconnect the sensor array: passo 4, imagem 2 %32
    • Carefully lift the back cover to access the sensor array connector.
    • Use a spudger to disconnect the sensor array from the motherboard.
  5. Samsung Galaxy Watch Active2 Motherboard Replacement, Remove the back cover: passo 5, imagem 1 %32
    • Remove the back cover.
  6. Samsung Galaxy Watch Active2 Motherboard Replacement, Disconnect the display and speaker: passo 6, imagem 1 %32 Samsung Galaxy Watch Active2 Motherboard Replacement, Disconnect the display and speaker: passo 6, imagem 2 %32 Samsung Galaxy Watch Active2 Motherboard Replacement, Disconnect the display and speaker: passo 6, imagem 3 %32
    • Use a spudger to disconnect the display assembly and the speaker.
  7. Samsung Galaxy Watch Active2 Motherboard Replacement, Disconnect the barometric sensor, buttons, and mic: passo 7, imagem 1 %32 Samsung Galaxy Watch Active2 Motherboard Replacement, Disconnect the barometric sensor, buttons, and mic: passo 7, imagem 2 %32 Samsung Galaxy Watch Active2 Motherboard Replacement, Disconnect the barometric sensor, buttons, and mic: passo 7, imagem 3 %32
    • Use a spudger to disconnect the barometric sensor, the buttons, and the microphone.
  8. Samsung Galaxy Watch Active2 Motherboard Replacement, Lift the core assembly: passo 8, imagem 1 %32 Samsung Galaxy Watch Active2 Motherboard Replacement, Lift the core assembly: passo 8, imagem 2 %32
    • Place a spudger underneath the motherboard at the top right next to the display connector.
    • Slightly twist and lever the spudger to loosen the core assembly.
    • It might help to also check the comments below this and the next step if you’re having difficulties.
  9. Samsung Galaxy Watch Active2 Motherboard Replacement, Remove the core assembly: passo 9, imagem 1 %32 Samsung Galaxy Watch Active2 Motherboard Replacement, Remove the core assembly: passo 9, imagem 2 %32 Samsung Galaxy Watch Active2 Motherboard Replacement, Remove the core assembly: passo 9, imagem 3 %32
    • Grab the core assembly and carefully slide it out from under the cables.
    • Remove the core assembly.
  10. Samsung Galaxy Watch Active2 Motherboard Replacement, Flip the Core Assembly: passo 10, imagem 1 %32
    • Flip the core assembly over so the motherboard faces down.
  11. Samsung Galaxy Watch Active2 Motherboard Replacement, Undo the top button: passo 11, imagem 1 %32 Samsung Galaxy Watch Active2 Motherboard Replacement, Undo the top button: passo 11, imagem 2 %32
    • Use the tip of an opening pick to peel the top button off the plastic frame.
  12. Samsung Galaxy Watch Active2 Motherboard Replacement, Remove the motherboard screw: passo 12, imagem 1 %32
    • Use a Phillips screwdriver to remove the 4.4 mm-long screw holding the motherboard in place.
  13. Samsung Galaxy Watch Active2 Motherboard Replacement, Free the motherboard: passo 13, imagem 1 %32 Samsung Galaxy Watch Active2 Motherboard Replacement, Free the motherboard: passo 13, imagem 2 %32
    • Place the flat end of a spudger between the motherboard and the plastic frame near the copper coil at the bottom right.
    • Twist the spudger to free the motherboard from the plastic tabs.
  14. Samsung Galaxy Watch Active2 Motherboard Replacement, Remove the motherboard: passo 14, imagem 1 %32
    • Slide the motherboard out from under the remaining plastic tabs to remove it.
Conclusão
4 outras pessoas executaram este guia.
Tobias Isakeit
Membro desde: 03/31/14
119.540 Reputação
Autoria de 189 guias
Equipe
13 comentários
Hi, I am having issues with bluetooth, is it a replacement or do I need to swap the MB? Thank you
Bruno Albin - Responder
When you have ruled out any software issues (tried restart, factory reset, software update, etc) then this is most likely a MB replacement since all the modules are integrated on that tiny thing.
Tobias Isakeit -
does the watch active have the same motherboard as the watch active 2
aqoullam6 - Responder
Nope, the Watch Active has a different motherboard.
Tobias Isakeit -
My watch stopped vibrating all together, which part do I need to replace?
Melissa McEleney - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 10
Últimos 7 dias: 55
Últimos 30 dias: 235
Duração total: 9,136
