Ir para o conteúdo principal
Samsung Galaxy View Kickstand Replacement
O que você precisa
  1. Samsung Galaxy View Kickstand Replacement, Kickstand: passo 1, imagem 1 %32
    • Place the device on a hard flat surface with its screen facing downwards.
    • Rotate the the kickstand so that the handle grip hole is up in the air and not touching the back of the tablet.
    Pergunte ao FixBot
    Comentar
  2. Samsung Galaxy View Kickstand Replacement: passo 2, imagem 1 %32 Samsung Galaxy View Kickstand Replacement: passo 2, imagem 2 %32 Samsung Galaxy View Kickstand Replacement: passo 2, imagem 3 %32
    • Stick the pointy end of the spudger into the circular opening of the leftmost metallic latch.
    • With the spudger still inserted, pry the spudger to the right pushing the latch opening along with it.
    • Once the latch is moved to the right, pull up on the left side of the kickstand, releasing it from the back of the tablet.
    • Repeat the previous steps for the rightmost latch, and then lift the kickstand off the back of the tablet.
    Pergunte ao FixBot
    Comentar
Conclusão
5 outras pessoas executaram este guia.
Equipe
Cal Poly, Team 4-5, Livingston Fall 2016 Membro de Cal Poly, Team 4-5, Livingston Fall 2016
CPSU-LIVINGSTON-F16S4G5
4 Membros
Autoria de 12 guias
15Comentários do guia
Where do u buy a replacement kickstand
Bethann Stokes - Responder Compartilhar
The only thing I could find was a broken one on eBay for parts ......
cindylou73 - Responder Compartilhar
I have the same issue! kickstand broke in half (it fell and got broken) and cannot find replacement
Carlos Sierra - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 3
Últimos 7 dias: 11
Últimos 30 dias: 47
Ao todo: 9,565
