Introdução
This replacement requires screen and central panel removal. Note that the connector between the camera and the motherboard flips up for removal.
O que você precisa
Heat the iOpeners in a microwave for 1-2 minutes.
Place heated iOpeners on screen edges to heat the adhesive.
Remove the 17 silver 3.0 mm Phillips head screws located around the edge of the device using the screwdriver.
Using the tweezers, remove the green protective film from the connector between the rear camera and the motherboard.
Uma outra pessoa concluiu este guia.
