Introdução
A broken headphone jack means that audio from your headphones is poor or nonexistent.
O que você precisa
Using the Philips #000 screwdriver, remove the seventeen 2.74 mm screws around the edges.
Remove the two 2.74 mm black screws in the middle of the tablet with the Philips #000 screwdriver.
Locate the headphone jack towards the bottom right-hand side.
Using the plastic opening tool, lift up the press-fit connector.
