Ir para o conteúdo principal
Samsung Galaxy Tab S2 9.7 AT&T Camera Replacement
O que você precisa
  1. Samsung Galaxy Tab S2 9.7 AT&T Camera Replacement, Screen: passo 1, imagem 1 %32 Samsung Galaxy Tab S2 9.7 AT&T Camera Replacement, Screen: passo 1, imagem 2 %32
    • Apply the heat gun around the edges of the tablet to melt the adhesive glue.
    • Do not allow the gun to remain still for more than two seconds, so that you do not melt the plastic around the screen.
    • If you do not have access to a heat gun, you may also use an iOpener or a hair dryer. Refer to the iOpener guide for extra help.
  2. Samsung Galaxy Tab S2 9.7 AT&T Camera Replacement: passo 2, imagem 1 %32 Samsung Galaxy Tab S2 9.7 AT&T Camera Replacement: passo 2, imagem 2 %32
    • Apply the suction to the bottom or top right corner.
    • Use the plastic opening tool at several points around the screen while the suction is being applied to pop the screen out.
  3. Samsung Galaxy Tab S2 9.7 AT&T Camera Replacement: passo 3, imagem 1 %32
    • Once the screen is detached, open the tablet like a book.
    • Gently open the tablet, and do not pull the pieces apart since you can risk damaging the orange ribbon cable.
  4. Samsung Galaxy Tab S2 9.7 AT&T Camera Replacement: passo 4, imagem 1 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • Using the precision tweezers, remove the silver tape that is holding the orange ribbon cable connecting the two pieces.
  5. Samsung Galaxy Tab S2 9.7 AT&T Camera Replacement: passo 5, imagem 1 %32
    • Using the precision tweezers, remove the small press-fit connector from the body of the tablet.
  6. Samsung Galaxy Tab S2 9.7 AT&T Camera Replacement, Screws: passo 6, imagem 1 %32 Samsung Galaxy Tab S2 9.7 AT&T Camera Replacement, Screws: passo 6, imagem 2 %32
    • Using the Philips #000 screwdriver, remove the seventeen 2.74 mm screws around the edges.
    • Remove the two 2.74 mm black screws in the middle of the tablet with the Philips #000 screwdriver.
    • Put the screws on a magnetic project mat or in a container so that you do not lose them.
  7. Samsung Galaxy Tab S2 9.7 AT&T Camera Replacement: passo 7, imagem 1 %32 Samsung Galaxy Tab S2 9.7 AT&T Camera Replacement: passo 7, imagem 2 %32 Samsung Galaxy Tab S2 9.7 AT&T Camera Replacement: passo 7, imagem 3 %32
    • Take the plastic opening tool around the tablet to remove the motherboard from the device.
  8. Samsung Galaxy Tab S2 9.7 AT&T Camera Replacement, Camera: passo 8, imagem 1 %32 Samsung Galaxy Tab S2 9.7 AT&T Camera Replacement, Camera: passo 8, imagem 2 %32 Samsung Galaxy Tab S2 9.7 AT&T Camera Replacement, Camera: passo 8, imagem 3 %32
    Comprar
    • Locate the two cameras at the top of the motherboard.
    • To remove the bigger, back-facing camera, use the precision tweezers to slide the silver ribbon cable out of the ZIF connector.
  9. Samsung Galaxy Tab S2 9.7 AT&T Camera Replacement: passo 9, imagem 1 %32 Samsung Galaxy Tab S2 9.7 AT&T Camera Replacement: passo 9, imagem 2 %32
    • To remove the smaller, front-facing camera, use the precision tweezers to disconnect the press-fit connector.
    • Carefully detach the camera using the precision tweezers.
Conclusão
Uma outra pessoa concluiu este guia.
Joy Harris
Membro desde: 02/15/17
814 Reputação
Autoria de 7 guias
Equipe
USF Tampa, Team S3-G4, Sullivan Spring 2017 Membro de USF Tampa, Team S3-G4, Sullivan Spring 2017
USFT-SULLIVAN-S17S3G4
Membros da 3
Autoria de 14 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 8
Duração total: 329
