Ir para o conteúdo principal
Samsung Galaxy Tab 3 10.1 Motherboard Replacement
O que você precisa
  1. Samsung Galaxy Tab 3 10.1 Motherboard Replacement, Rear Case: passo 1, imagem 1 %32 Samsung Galaxy Tab 3 10.1 Motherboard Replacement, Rear Case: passo 1, imagem 2 %32
    • Insert an opening pick between the rear case and the plastic rim.
    • You may need to add multiple picks to detach the clips.
    • Slide the pick along the edge of the rear case until you release the plastic clips attaching the rear case to the display.
    • Continue to slide the pick around the edge of the rear case until all clips are released.
  2. Samsung Galaxy Tab 3 10.1 Motherboard Replacement: passo 2, imagem 1 %32 Samsung Galaxy Tab 3 10.1 Motherboard Replacement: passo 2, imagem 2 %32
    • Lift the case up to remove it.
  3. Samsung Galaxy Tab 3 10.1 Motherboard Replacement, Battery: passo 3, imagem 1 %32 Samsung Galaxy Tab 3 10.1 Motherboard Replacement, Battery: passo 3, imagem 2 %32 Samsung Galaxy Tab 3 10.1 Motherboard Replacement, Battery: passo 3, imagem 3 %32
    • Use the flat end of a nlyon spudger to pry up the black plastic tabs securing the two ZIF connectors.
  4. Samsung Galaxy Tab 3 10.1 Motherboard Replacement: passo 4, imagem 1 %32 Samsung Galaxy Tab 3 10.1 Motherboard Replacement: passo 4, imagem 2 %32
    • Use the flat end of a nylon spudger to pry up the brown plastic tab securing the orange ribbon cable.
  5. Samsung Galaxy Tab 3 10.1 Motherboard Replacement: passo 5, imagem 1 %32 Samsung Galaxy Tab 3 10.1 Motherboard Replacement: passo 5, imagem 2 %32 Samsung Galaxy Tab 3 10.1 Motherboard Replacement: passo 5, imagem 3 %32
    • Remove all three ribbon cables by gently pulling the cables away from the ZIF connectors.
  6. Samsung Galaxy Tab 3 10.1 Motherboard Replacement: passo 6, imagem 1 %32
    • Use a Phillips #000 screwdriver to remove the ten 3mm screws securing the battery to the chassis.
  7. Samsung Galaxy Tab 3 10.1 Motherboard Replacement: passo 7, imagem 1 %32 Samsung Galaxy Tab 3 10.1 Motherboard Replacement: passo 7, imagem 2 %32
    • Use the pointed end of a nylon spudger to pry the two battery connections away from the motherboard.
  8. Samsung Galaxy Tab 3 10.1 Motherboard Replacement: passo 8, imagem 1 %32 Samsung Galaxy Tab 3 10.1 Motherboard Replacement: passo 8, imagem 2 %32
    • Lift with a nylon spudger to remove the battery.
  9. Samsung Galaxy Tab 3 10.1 Motherboard Replacement, Motherboard: passo 9, imagem 1 %32 Samsung Galaxy Tab 3 10.1 Motherboard Replacement, Motherboard: passo 9, imagem 2 %32
    • Insert an opening pick between the plastic frame and the screen.
    • Slide the opening pick around the perimeter of the screen.
    • You will hear clicking noises as each plastic clip is released from the display chassis.
  10. Samsung Galaxy Tab 3 10.1 Motherboard Replacement: passo 10, imagem 1 %32
    • Lift the plastic frame to remove.
    • Avoid the three delicate ribbon cables.
  11. Samsung Galaxy Tab 3 10.1 Motherboard Replacement: passo 11, imagem 1 %32
    • Use a Phillips #000 screwdriver to remove the 3mm screw attaching the motherboard to the display chassis.
  12. Samsung Galaxy Tab 3 10.1 Motherboard Replacement: passo 12, imagem 1 %32 Samsung Galaxy Tab 3 10.1 Motherboard Replacement: passo 12, imagem 2 %32 Samsung Galaxy Tab 3 10.1 Motherboard Replacement: passo 12, imagem 3 %32
    • Use a nylon spudger to flip up the eight press-fit connectors from the motherboard.
    • The vibration motor is missing from these photos.
  13. Samsung Galaxy Tab 3 10.1 Motherboard Replacement: passo 13, imagem 1 %32 Samsung Galaxy Tab 3 10.1 Motherboard Replacement: passo 13, imagem 2 %32
    • Use nylon-tipped tweezers to remove the motherboard.
Conclusão
12 outras pessoas executaram este guia.
Corey Brown
Membro desde: 06/24/16
8.518 Reputação
Autoria de 11 guias
3 comentários
Great guide, project completed.
Edgar Merced - Responder
Simplemente GENIAL!!!!
Muy claro.
Felicitaciones.
Cuenten con mis aportes al foro
Ahora que pude retirar placa base voy a ver esquemático, porque WIFI se desactiva . No funciona.
Saludos
DARIO GASTAUDO - Responder
very easy to destroy the Galaxy. finicky to the max!
ein Stein - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 41
Duração total: 9,357
