Ir para o conteúdo principal
Samsung Galaxy Tab 3 10.1 LED Light Replacement
O que você precisa
  1. Samsung Galaxy Tab 3 10.1 LED Light Replacement, Rear Case: passo 1, imagem 1 %32 Samsung Galaxy Tab 3 10.1 LED Light Replacement, Rear Case: passo 1, imagem 2 %32
    • Insert an opening pick between the rear case and the plastic rim.
    • You may need to add multiple picks to detach the clips.
    • Slide the pick along the edge of the rear case until you release the plastic clips attaching the rear case to the display.
    • Continue to slide the pick around the edge of the rear case until all clips are released.
  2. Samsung Galaxy Tab 3 10.1 LED Light Replacement: passo 2, imagem 1 %32 Samsung Galaxy Tab 3 10.1 LED Light Replacement: passo 2, imagem 2 %32
    • Lift the case up to remove it.
  3. Samsung Galaxy Tab 3 10.1 LED Light Replacement, LED Light: passo 3, imagem 1 %32 Samsung Galaxy Tab 3 10.1 LED Light Replacement, LED Light: passo 3, imagem 2 %32
    • Insert an opening pick between the plastic frame and the screen.
    • Slide the opening pick around the perimeter of the screen.
    • You will hear clicking noises as each plastic clip is released from the display chassis.
  4. Samsung Galaxy Tab 3 10.1 LED Light Replacement: passo 4, imagem 1 %32
    • Lift the plastic frame to remove.
    • Avoid the three delicate ribbon cables.
  5. Samsung Galaxy Tab 3 10.1 LED Light Replacement: passo 5, imagem 1 %32 Samsung Galaxy Tab 3 10.1 LED Light Replacement: passo 5, imagem 2 %32 Samsung Galaxy Tab 3 10.1 LED Light Replacement: passo 5, imagem 3 %32
    • Use the flat end of the spudger to flip up the press-fit connector attaching the LED to the motherboard.
    • Remove the LED indicator light by gently pulling upward with nylon-tipped tweezers.
Conclusão
4 outras pessoas executaram este guia.
Corey Brown
Membro desde: 06/24/16
8.548 Reputação
Autoria de 11 guias
Um comentário
Above article is useful for removing LED Light.
Which LED are we removing - Camera Flash or screen display LED?
How to fit new LED Light?
Please reply. I am facing issues with screen display and flash for camera is also not working
Ashwini Dughad - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 6
Últimos 30 dias: 25
Duração total: 4,117
