Ir para o conteúdo principal
Samsung Galaxy SIII Mini VE Front Camera Replacement
O que você precisa
  1. Samsung Galaxy SIII Mini VE Front Camera Replacement, Removing Rear Casing: passo 1, imagem 1 %32 Samsung Galaxy SIII Mini VE Front Camera Replacement, Removing Rear Casing: passo 1, imagem 2 %32 Samsung Galaxy SIII Mini VE Front Camera Replacement, Removing Rear Casing: passo 1, imagem 3 %32
    • Flip your phone so you are facing the back.
    • Locate the notch at the top and gently use your finger or an opening tool to remove the rear casing.
    Pergunte ao FixBot
    Comentar
  2. Samsung Galaxy SIII Mini VE Front Camera Replacement, Removing Battery: passo 2, imagem 1 %32 Samsung Galaxy SIII Mini VE Front Camera Replacement, Removing Battery: passo 2, imagem 2 %32
    • Use your finger or an opening tool to pry the battery out of the phone.
    Pergunte ao FixBot
    Comentar
  3. Samsung Galaxy SIII Mini VE Front Camera Replacement, Removing Screws: passo 3, imagem 1 %32
    • Use the Phillips #000 Screwdriver to remove the 10, 4mm screws holding the plastic frame in place.
    Pergunte ao FixBot
    Comentar
  4. Samsung Galaxy SIII Mini VE Front Camera Replacement: passo 4, imagem 1 %32 Samsung Galaxy SIII Mini VE Front Camera Replacement: passo 4, imagem 2 %32
    • Using an opening tool, gently separate the plastic framing from the phone.
    Pergunte ao FixBot
    Comentar
  5. Samsung Galaxy SIII Mini VE Front Camera Replacement, Removing Circuit Board: passo 5, imagem 1 %32 Samsung Galaxy SIII Mini VE Front Camera Replacement, Removing Circuit Board: passo 5, imagem 2 %32 Samsung Galaxy SIII Mini VE Front Camera Replacement, Removing Circuit Board: passo 5, imagem 3 %32
    Ferramenta utilizada neste passo:
    • Unhook the two electrical connections at the bottom of the phone using your fingernail or a spudger.
    • Next, use the spudger and tweezers to remove the speaker at the top of the phone.
    • Once the 3 components have detached, the circuit board should release from the phone except for 1 connection on the underside.
    • Detach this connection using the spudger.
    Pergunte ao FixBot
    Comentar
  6. Samsung Galaxy SIII Mini VE Front Camera Replacement, Removing Front Camera: passo 6, imagem 1 %32 Samsung Galaxy SIII Mini VE Front Camera Replacement, Removing Front Camera: passo 6, imagem 2 %32 Samsung Galaxy SIII Mini VE Front Camera Replacement, Removing Front Camera: passo 6, imagem 3 %32
    • Locate the front camera connection.
    • Using the tweezers, lift the holding tab at the base of the ribbon wire.
    • Again, using the tweezers, gently pull the front camera out and away from the phone.
    Pergunte ao FixBot
    Comentar
Conclusão
Megan
Membro desde: 10/23/14
1.255 Reputação
Autoria de 6 guias
Equipe
Michigan Tech, Team 1-8, Lauer Fall 2014 Membro de Michigan Tech, Team 1-8, Lauer Fall 2014
MTU-LAUER-F14S1G8
3 Membros
Autoria de 12 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 3
Últimos 7 dias: 6
Últimos 30 dias: 19
Ao todo: 1,480
