Este guia tem alterações mais recentes. Mudar para a última versão não verificada.
Introdução
Cracked screen? Touch not working? Bad OLED display? Use this guide to replace the display + touch panel assembly in your Galaxy S8+ and restore it to perfect working order.
Note: This guide instructs you to replace only the display while leaving the original frame, motherboard, and battery in place. However, some replacement screens for this phone come pre-installed in a new frame (a.k.a. chassis), which requires a very different procedure—transplanting your phone's internals and installing a new battery. Make sure you have the correct part before starting this guide. To replace the entire screen assembly together with a new frame, follow this guide instead.
If the frame is damaged or bent, it's important to replace it, or else the new screen may not mount correctly and can suffer damage from uneven pressure.
The process of separating the display from the frame usually destroys the display, so don't follow this guide unless you intend to replace the display.
O que você precisa
Prepare an iOpener and heat the back of the phone along its left edge for about two minutes. This will help soften the adhesive securing the back cover.
In the following steps, you'll be cutting through the adhesive securing the back cover.
As seen from outside the phone, you'll be slicing through the adhesive in the areas shown:
Thick portions of adhesive
Thin areas of adhesive
Avoid prying or slicing in this area, to protect the fingerprint sensor flex cable.
Remove the back cover.
Use tweezers to peel away any remaining adhesive from the phone's chassis. Then clean the adhesion areas with high concentration isopropyl alcohol (at least 90%) and a lint-free cloth to prep the surface for the new adhesive.
Peel the adhesive backing off of the new rear glass, carefully line up one edge of the glass against the phone chassis, and firmly press the glass onto the phone.
Remove the eleven 3.7 mm Phillips screws securing the wireless charging coil + antenna assembly.
If any screws are difficult to remove even when fully loosened, you can pull them out with tweezers.
Using a spudger, disconnect the display by carefully prying up its flex cable connector from the socket on the motherboard.
80 outras pessoas executaram este guia.
14 comentários
After replacing LCD my phone showing message that “Battery temperature too low“ and pause charging. There are some video showing install wireless charging module after replacing LCD would solve this issue but for me it still not charging even with wireless charging module on. Any suggestion?
samion 2048, This is because the device was turned on before attaching the wireless charging coil. The coil houses the ambient temperature sensor.
once you replace the front screen is the phone still water resistant?
It will be water resistant if you reapply the nescassery adhesives.
I replaced my display with a another display with mid frame attatched already.all i did was change over my mother board,charging port and such and now if i power the phone on i feel it vibrate and see a blue led light up but that is all it does.screen is black and i can feel the vibration feedback if i touch the screen but nothing shows.going out of my mind trying to figure out what went wrong.
