Esta versão pode conter edições incorretas. Mude para o último instantâneo verificado.
O que você precisa
Vídeo de Apresentação
Encha uma panela ou frigideira com água suficiente para submergir completamente um iOpener.
Aqueça a água até ferver. Desligue o fogo.
Coloque um iOpener na água quente por 2 a 3 minutos. Certifique-se de que o iOpener esteja totalmente submerso na água.
Use um pegador para retirar o iOpener aquecido da água quente.
Seque bem o iOpener com uma toalha.
Sua bolsa térmica iOpener está pronta para o uso! Se precisar reaquecer o iOpener, aqueça a água até ferver, desligue o fogo e coloque o iOpener na água por 2 a 3 minutos.
Este passo não foi traduzido. Ajude a traduzi-lo
Heat an iOpener and apply it to a long edge of the S8 for about 2 minutes.
In the following steps you will be cutting through the adhesive around the edge of the rear glass panel.
The adhesive on the rear case is laid out as seen in the first image.
The prying pattern as seen from the outside of the phone is as follows:
Thick portions of adhesive
Thin areas of adhesive
Avoid prying here, to protect the fingerprint sensor.
Once the back panel is warm to the touch, apply a suction cup as close to the heated edge of the phone as you can while avoiding the curved edge.
Lift on the suction cup, and insert an opening pick under the rear glass.
Once you have the tool firmly inserted into the glass, reheat and reapply the iOpener to soften the adhesive.
Slide the opening pick down the side of the phone, separating the adhesive.
Repeat the previous heating and cutting procedure for the remaining three sides of the phone.
Leave an opening pick on each side as you continue to the next to prevent the adhesive from resealing.
Use the opening picks to slice through any remaining adhesive and open the phone slightly.
Remove the glass from the phone.
Use tweezers to peel away any remaining adhesive from the phone's chassis. Then clean the adhesion areas with high concentration isopropyl alcohol (at least 90%) and a lint-free cloth to prep the surface for the new adhesive.
Peel the adhesive backing off of the new rear glass, carefully line up one edge of the glass against the phone chassis, and firmly press the glass onto the phone.
Remove eleven 3.7 mm screws using a Phillips #000 screwdriver.
Use the flat end of a spudger to disconnect the battery connector.
Use the point of a spudger to disconnect the headphone jack connector.
Insert the point of a spudger in between the headphone jack and the board, against the corner of the jack closest to the ribbon cable.
Use the spudger to gently pry the headphone jack out of the board.
Remove the headphone jack.
13 outras pessoas executaram este guia.
