Introdução
This guide will teach you how to remove and replace the motherboard in the Samsung Galaxy S7 Active.
O que você precisa
Melt the adhesive on the screen by applying a blow dryer directly on the screen.
Use tweezers to disconnect the front camera from the battery.
Use a Phillips 000 screwdriver to remove the screw covering the proximity sensor.
3 outras pessoas executaram este guia.
