Introdução
This guide will show you how to replace the Samsung Galaxy S7 Active front camera.
O que você precisa
Melt the adhesive on the screen by applying a blow dryer directly on the screen.
Use tweezers to disconnect the front camera from the battery.
Use a Phillips 000 screwdriver to remove the screw covering the proximity sensor.
Use tweezers to remove the connection between the motherboard and the front camera.
Quase terminado!
Conclusão
