Ir para o conteúdo principal
Samsung Galaxy S6 Active Power Button Replacement
O que você precisa
  1. Samsung Galaxy S6 Active Power Button Replacement, SIM Card: passo 1, imagem 1 %32 Samsung Galaxy S6 Active Power Button Replacement, SIM Card: passo 1, imagem 2 %32
    • Insert your fingernail or a plastic opening tool into the pivot on the side of the SIM tray.
    • Pry open the tray to get it out of the socket.
    Pergunte ao FixBot
    Comentar
  2. Samsung Galaxy S6 Active Power Button Replacement: passo 2, imagem 1 %32
    • Remove the SIM tray with SIM card from the phone.
    Pergunte ao FixBot
    Comentar
  3. Samsung Galaxy S6 Active Power Button Replacement, Display Assembly: passo 3, imagem 1 %32 Samsung Galaxy S6 Active Power Button Replacement, Display Assembly: passo 3, imagem 2 %32 Samsung Galaxy S6 Active Power Button Replacement, Display Assembly: passo 3, imagem 3 %32
    • Heat the front face (sides, top, bottom) of the phone with the iOpener, a hair dryer, or a heat gun for 60 seconds to loosen the adhesive around the edge of the glass.
    • If using an iOpener, heat it in a microwave for thirty seconds.
    Pergunte ao FixBot
    Comentar
  4. Samsung Galaxy S6 Active Power Button Replacement: passo 4, imagem 1 %32
    • Attach a suction cup to the lower half of the screen.
    Pergunte ao FixBot
    Comentar
  5. Samsung Galaxy S6 Active Power Button Replacement: passo 5, imagem 1 %32 Samsung Galaxy S6 Active Power Button Replacement: passo 5, imagem 2 %32
    • Using the suction cup, pull gently the lower half of the panel.
    • If you pull too hard you may break the display. If you still feel resistance repeat Step 3, leaving the iOpener on longer.
    Pergunte ao FixBot
    Comentar
  6. Samsung Galaxy S6 Active Power Button Replacement: passo 6, imagem 1 %32 Samsung Galaxy S6 Active Power Button Replacement: passo 6, imagem 2 %32 Samsung Galaxy S6 Active Power Button Replacement: passo 6, imagem 3 %32
    • Once you’ve opened a large enough gap, insert a plastic tool at the bottom, between the glass and the rest of frame of the phone.
    • Slide the plastic opening tool around the screen, prying the display gently away from the body
    Pergunte ao FixBot
    Comentar
  7. Samsung Galaxy S6 Active Power Button Replacement: passo 7, imagem 1 %32
    • Pull the lower half of the screen screen with the suction cup while holding down the frame of the phone to separate both components.
    • Only lift the lower part of the screen. It is connected with a clip to the top of the motherboard and can rip off if you pull too hard.
    Pergunte ao FixBot
    Comentar
  8. Samsung Galaxy S6 Active Power Button Replacement: passo 8, imagem 1 %32 Samsung Galaxy S6 Active Power Button Replacement: passo 8, imagem 2 %32 Samsung Galaxy S6 Active Power Button Replacement: passo 8, imagem 3 %32
    Ferramenta utilizada neste passo:
    • Once the glass is off, you will see a small clip covering the screen connection to the motherboard at the top of the phone. Use tweezers to grab the clip by the crease on its side and pull it out.
    Pergunte ao FixBot
    Comentar
  9. Samsung Galaxy S6 Active Power Button Replacement: passo 9, imagem 1 %32
    • Undo the screen connection with a plastic tool.
    Pergunte ao FixBot
    Comentar
  10. Samsung Galaxy S6 Active Power Button Replacement: passo 10, imagem 1 %32
    • Remove the display assembly (LCD and Digitizer).
    Pergunte ao FixBot
    Comentar
  11. Samsung Galaxy S6 Active Power Button Replacement, Battery: passo 11, imagem 1 %32 Samsung Galaxy S6 Active Power Button Replacement, Battery: passo 11, imagem 2 %32
    • Use the Phillips Head Screwdriver sized PH000 to remove the sixteen 4mm screws from the frame.
    Pergunte ao FixBot
    Comentar
  12. Samsung Galaxy S6 Active Power Button Replacement: passo 12, imagem 1 %32
    • Put a little pressure on the top, on the bottom, and on the sides of the phone to separate the rear case.
    • You will hear the clips start undoing themselves.
    Pergunte ao FixBot
    Comentar
  13. Samsung Galaxy S6 Active Power Button Replacement: passo 13, imagem 1 %32 Samsung Galaxy S6 Active Power Button Replacement: passo 13, imagem 2 %32
    • Once all the clips have popped, pull out the rear case to separate it from the frame with the battery.
    • The battery will be on the back side of this frame.
    Pergunte ao FixBot
    Comentar
  14. Samsung Galaxy S6 Active Power Button Replacement: passo 14, imagem 1 %32
    • Insert a plastic opening tool on the side of the frame and pull out the battery.
    Pergunte ao FixBot
    Comentar
  15. Samsung Galaxy S6 Active Power Button Replacement: passo 15, imagem 1 %32 Samsung Galaxy S6 Active Power Button Replacement: passo 15, imagem 2 %32
    • Remove the battery from the frame.
    Pergunte ao FixBot
    Comentar
  16. Samsung Galaxy S6 Active Power Button Replacement, Motherboard: passo 16, imagem 1 %32 Samsung Galaxy S6 Active Power Button Replacement, Motherboard: passo 16, imagem 2 %32 Samsung Galaxy S6 Active Power Button Replacement, Motherboard: passo 16, imagem 3 %32
    • Use a plastic tool to undo all the connections in the motherboard.
    • There are three connections that have to be removed.
    Pergunte ao FixBot
    Comentar
  17. Samsung Galaxy S6 Active Power Button Replacement: passo 17, imagem 1 %32 Samsung Galaxy S6 Active Power Button Replacement: passo 17, imagem 2 %32
    • Insert the flats end of the spudger below the motherboard and twist it to pry the board up.
    Pergunte ao FixBot
    Comentar
  18. Samsung Galaxy S6 Active Power Button Replacement: passo 18, imagem 1 %32
    • Remove the motherboard from the rear case.
    Pergunte ao FixBot
    Comentar
  19. Samsung Galaxy S6 Active Power Button Replacement, Power Button: passo 19, imagem 1 %32
    • Put a little pressure on the top, on the bottom, and on the sides of the phone to separate it from the plastic cover.
    Pergunte ao FixBot
    Comentar
  20. Samsung Galaxy S6 Active Power Button Replacement: passo 20, imagem 1 %32 Samsung Galaxy S6 Active Power Button Replacement: passo 20, imagem 2 %32
    • Once you see a large enough gap, insert a plastic tool between the frame and the plastic cover and slide it around the phone to separate both components.
    Pergunte ao FixBot
    Comentar
  21. Samsung Galaxy S6 Active Power Button Replacement: passo 21, imagem 1 %32
    • Remove the plastic cover from the phone.
    Pergunte ao FixBot
    Comentar
  22. Samsung Galaxy S6 Active Power Button Replacement: passo 22, imagem 1 %32
    • Insert a plastic tool between the frame of the phone and the back cover at the top left corner.
    Pergunte ao FixBot
    Comentar
  23. Samsung Galaxy S6 Active Power Button Replacement: passo 23, imagem 1 %32
    • Leave the plastic tool inside in order to access the power button connection.
    Pergunte ao FixBot
    Comentar
  24. Samsung Galaxy S6 Active Power Button Replacement: passo 24, imagem 1 %32 Samsung Galaxy S6 Active Power Button Replacement: passo 24, imagem 2 %32
    • Use the tweezers to pry up the power button ribbon cable until the only thing attached to the frame are the contacts.
    • Pulling too hard can rip off the ribbon cable. Make sure not to pull the entire body together.
    Pergunte ao FixBot
    Comentar
  25. Samsung Galaxy S6 Active Power Button Replacement: passo 25, imagem 1 %32 Samsung Galaxy S6 Active Power Button Replacement: passo 25, imagem 2 %32
    • Insert the tweezers under the contact points to undo the connection.
    Pergunte ao FixBot
    Comentar
  26. Samsung Galaxy S6 Active Power Button Replacement: passo 26, imagem 1 %32
    • Use the tweezers to remove the power button bracket.
    Pergunte ao FixBot
    Comentar
  27. Samsung Galaxy S6 Active Power Button Replacement: passo 27, imagem 1 %32
    • The power button is located on the plastic cover.
    • Use the tweezers to push the power button out of the frame.
    Pergunte ao FixBot
    Comentar
  28. Samsung Galaxy S6 Active Power Button Replacement: passo 28, imagem 1 %32
    • Remove the power button from the frame.
    Pergunte ao FixBot
    Comentar
Conclusão
Uma outra pessoa concluiu este guia.
Lucia Valbuena
Membro desde: 02/15/17
2.538 Reputação
Autoria de 8 guias
Equipe
USF Tampa, Team 1-5, Sullivan Spring 2017 Membro de USF Tampa, Team 1-5, Sullivan Spring 2017
USFT-SULLIVAN-S17S1G5
3 Membros
Autoria de 33 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 3
Últimos 30 dias: 26
Ao todo: 1,779
