Ir para o conteúdo principal
Samsung Galaxy S4 Mini Charging Assembly
O que você precisa
  1. Samsung Galaxy S4 Mini Charging Assembly, Battery: passo 1, imagem 1 %32
    • Press and hold the END key to power the phone down.
    Pergunte ao FixBot
    Comentar
  2. Samsung Galaxy S4 Mini Charging Assembly: passo 2, imagem 1 %32
    • Remove the back cover of the cell phone using a plastic opening tool.
    Pergunte ao FixBot
    Comentar
  3. Samsung Galaxy S4 Mini Charging Assembly: passo 3, imagem 1 %32
    • Pry the battery out using a plastic opening tool.
    Pergunte ao FixBot
    Comentar
  4. Samsung Galaxy S4 Mini Charging Assembly, SIM Card: passo 4, imagem 1 %32 Samsung Galaxy S4 Mini Charging Assembly, SIM Card: passo 4, imagem 2 %32
    Ferramenta utilizada neste passo:
    • Using tweezers, remove the SIM card by sliding it towards the bottom of the device.
    Pergunte ao FixBot
    Comentar
  5. Samsung Galaxy S4 Mini Charging Assembly, SD Card: passo 5, imagem 1 %32
    • Using a nylon spudger, push through the hole at the top of the memory card holder to slide it out.
    Pergunte ao FixBot
    Comentar
  6. Samsung Galaxy S4 Mini Charging Assembly, Charging Assembly: passo 6, imagem 1 %32
    • Remove the 10 4.0 mm Phillips screws on the back of the phone using the #00 Phillips screwdriver.
    • Not needed, but Tweezers can be helpful in removing the screws from their holes, as their size makes removal a tad difficult.
    Pergunte ao FixBot
    Comentar
  7. Samsung Galaxy S4 Mini Charging Assembly: passo 7, imagem 1 %32
    • Starting at the USB port, slide a plastic tool around the perimeter of the phone between the rear housing and frame. As you work your way around the edge you will feel the clips release.
    Pergunte ao FixBot
    Comentar
  8. Samsung Galaxy S4 Mini Charging Assembly: passo 8, imagem 1 %32
    • Carefully separate the rear housing and the mid-frame to reveal the inside of the phone.
    Pergunte ao FixBot
    Comentar
  9. Samsung Galaxy S4 Mini Charging Assembly: passo 9, imagem 1 %32
    • Remove the 2 flex cables shown that attach to the USB board, Tweezers can be especially helpful here.
    Pergunte ao FixBot
    Comentar
  10. Samsung Galaxy S4 Mini Charging Assembly: passo 10, imagem 1 %32
    • Gently pry underneath the charging port using the plastic opening tool to separate it from the double sided tape below.
    Pergunte ao FixBot
    Comentar
  11. Samsung Galaxy S4 Mini Charging Assembly: passo 11, imagem 1 %32
    • Once its released, gently lift the main board and remove the USB board containing the charging port.
    Pergunte ao FixBot
    Comentar
Conclusão
35 outras pessoas executaram este guia.
Francis Barnett
Membro desde: 09/23/14
1.104 Reputação
Autoria de 1 guia
Equipe
USF Tampa, Team 9-2, Blackwell Fall 2014 Membro de USF Tampa, Team 9-2, Blackwell Fall 2014
USFT-BLACKWELL-F14S9G2
5 Membros
Autoria de 11 guias
4Comentários do guia
if i open the device like this, can i solder cables on the usb port to connect a wireless charging reciever?
Getriebesand - Responder Compartilhar
I was looking for the same solution, and I think it is possible, a closer look at the USB port from various spare parts suppliers, I was in doubt if mine would look the same as the one displayed here, after disassembling my phone, it turned out to be this one: http://bit.ly/1GR4SzP
And it is possible, when messuring connection points, it turns out CN2 on the bord is the +, and - you can fit onto the side of the USB connector itself.
Kenneth H. Nielsen - Responder Compartilhar
I have created a Guide describing the addition of wireless charging, it is in no way affecting the phones stability.
Works great with the S4 mini I9195 LTE version, but mind the different spare part (as linked above: http://bit.ly/1GR4SzP).
megaoetzwuchst - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 11
Últimos 30 dias: 45
Ao todo: 26,718
