Ir para o conteúdo principal
Samsung Galaxy S22 Ultra USB-C Port and Charging Board Replacement
O que você precisa
  1. Samsung Galaxy S22 Ultra USB-C Port and Charging Board Replacement, Remove the SIM card tray: passo 1, imagem 1 %32 Samsung Galaxy S22 Ultra USB-C Port and Charging Board Replacement, Remove the SIM card tray: passo 1, imagem 2 %32 Samsung Galaxy S22 Ultra USB-C Port and Charging Board Replacement, Remove the SIM card tray: passo 1, imagem 3 %32
    • Insert a SIM eject tool, bit, or straightened paper clip into the SIM card tray hole on the bottom edge of the phone.
    • Press the SIM eject tool into the SIM card tray hole to eject the SIM card tray.
    • Remove the SIM card tray.
    • If you accidentally inserted the SIM eject tool into a microphone hole, don't worry! You most likely didn't damage the microphone.
  2. Samsung Galaxy S22 Ultra USB-C Port and Charging Board Replacement, Heat the right edge: passo 2, imagem 1 %32
    • Heat an iOpener and apply it to the right edge of the back cover for two minutes.
    • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the phone—the display and internal battery are susceptible to heat damage.
  3. Samsung Galaxy S22 Ultra USB-C Port and Charging Board Replacement, Adhesive information: passo 3, imagem 1 %32 Samsung Galaxy S22 Ultra USB-C Port and Charging Board Replacement, Adhesive information: passo 3, imagem 2 %32
    • While you wait for the adhesive to soften, note the following:
    • There's adhesive securing the back cover around the perimeter of the frame.
    • The adhesive is strongest in the bottom right and top left corners.
  4. Samsung Galaxy S22 Ultra USB-C Port and Charging Board Replacement, Insert an opening pick: passo 4, imagem 1 %32 Samsung Galaxy S22 Ultra USB-C Port and Charging Board Replacement, Insert an opening pick: passo 4, imagem 2 %32 Samsung Galaxy S22 Ultra USB-C Port and Charging Board Replacement, Insert an opening pick: passo 4, imagem 3 %32
    • Apply a suction handle to the back cover, as close to the center of the right edge as possible.
    • Pull up on the suction handle with strong, steady force to create a gap between the cover and the frame.
    • If you have trouble creating a gap, apply more heat to further soften the adhesive. Follow the iOpener instructions to avoid overheating.
    • Insert an opening pick into the gap.
  5. Samsung Galaxy S22 Ultra USB-C Port and Charging Board Replacement, Slice the right adhesive: passo 5, imagem 1 %32 Samsung Galaxy S22 Ultra USB-C Port and Charging Board Replacement, Slice the right adhesive: passo 5, imagem 2 %32 Samsung Galaxy S22 Ultra USB-C Port and Charging Board Replacement, Slice the right adhesive: passo 5, imagem 3 %32
    • Slide the pick back and forth along the right edge to slice through the adhesive.
    • Leave the pick inserted near the bottom of the right edge to prevent the adhesive from resealing.
  6. Samsung Galaxy S22 Ultra USB-C Port and Charging Board Replacement, Heat the bottom edge: passo 6, imagem 1 %32
    • Apply a heated iOpener to the bottom edge of the back cover for two minutes.
  7. Samsung Galaxy S22 Ultra USB-C Port and Charging Board Replacement, Separate the corner adhesive: passo 7, imagem 1 %32 Samsung Galaxy S22 Ultra USB-C Port and Charging Board Replacement, Separate the corner adhesive: passo 7, imagem 2 %32 Samsung Galaxy S22 Ultra USB-C Port and Charging Board Replacement, Separate the corner adhesive: passo 7, imagem 3 %32
    • Insert a second opening pick at the bottom right corner.
    • Angle the pick upward to match the curved edge and rotate it around the bottom right corner.
    • Be careful while slicing around the corners, as the glass is very fragile here. Work slowly to avoid cracking the glass.
  8. Samsung Galaxy S22 Ultra USB-C Port and Charging Board Replacement, Slice the bottom adhesive: passo 8, imagem 1 %32 Samsung Galaxy S22 Ultra USB-C Port and Charging Board Replacement, Slice the bottom adhesive: passo 8, imagem 2 %32
    • Slide your opening pick to the bottom left corner to slice the adhesive.
    • Leave the pick in the bottom left corner to prevent the adhesive from resealing.
  9. Samsung Galaxy S22 Ultra USB-C Port and Charging Board Replacement, Heat the left edge: passo 9, imagem 1 %32
    • Apply a heated iOpener to the left edge of the back cover for two minutes.
  10. Samsung Galaxy S22 Ultra USB-C Port and Charging Board Replacement, Separate the corner adhesive: passo 10, imagem 1 %32 Samsung Galaxy S22 Ultra USB-C Port and Charging Board Replacement, Separate the corner adhesive: passo 10, imagem 2 %32 Samsung Galaxy S22 Ultra USB-C Port and Charging Board Replacement, Separate the corner adhesive: passo 10, imagem 3 %32
    • Insert a third opening pick at the bottom left corner.
    • Angle the pick upward to match the curved edge and rotate it around the bottom left corner.
  11. Samsung Galaxy S22 Ultra USB-C Port and Charging Board Replacement, Slice the left adhesive: passo 11, imagem 1 %32 Samsung Galaxy S22 Ultra USB-C Port and Charging Board Replacement, Slice the left adhesive: passo 11, imagem 2 %32 Samsung Galaxy S22 Ultra USB-C Port and Charging Board Replacement, Slice the left adhesive: passo 11, imagem 3 %32
    • Slide your opening pick along the left edge to slice the adhesive, stopping when you reach the power button.
    • Only insert the pick up to 5 mm, as you may damage the antenna flex cable or the power button cable.
    • Leave the pick in the left edge to prevent the adhesive from resealing.
  12. Samsung Galaxy S22 Ultra USB-C Port and Charging Board Replacement, Heat the top edge: passo 12, imagem 1 %32
    • Heat an iOpener and apply it to the top edge of the back cover for two minutes.
  13. Samsung Galaxy S22 Ultra USB-C Port and Charging Board Replacement, Separate the corner adhesive: passo 13, imagem 1 %32 Samsung Galaxy S22 Ultra USB-C Port and Charging Board Replacement, Separate the corner adhesive: passo 13, imagem 2 %32 Samsung Galaxy S22 Ultra USB-C Port and Charging Board Replacement, Separate the corner adhesive: passo 13, imagem 3 %32
    • Insert an opening pick in the gap at the top right edge.
    • Angle the pick upward to match the curved edge and rotate it around the top right corner.
  14. Samsung Galaxy S22 Ultra USB-C Port and Charging Board Replacement, Slice the top adhesive: passo 14, imagem 1 %32 Samsung Galaxy S22 Ultra USB-C Port and Charging Board Replacement, Slice the top adhesive: passo 14, imagem 2 %32
    • Slide the pick to the top left corner to slice the adhesive.
    • Only insert the pick up to 4 mm, as you may damage the cameras or sensors.
    • Leave the pick in to prevent the adhesive from resealing.
  15. Samsung Galaxy S22 Ultra USB-C Port and Charging Board Replacement, Separate the corner adhesive: passo 15, imagem 1 %32 Samsung Galaxy S22 Ultra USB-C Port and Charging Board Replacement, Separate the corner adhesive: passo 15, imagem 2 %32
    • Only insert the pick up to 4 mm, as you may damage the cameras.
    • Insert an opening pick in the gap at the top left edge.
    • Angle the pick upward to match the curved edge and rotate it around the top left corner.
  16. Samsung Galaxy S22 Ultra USB-C Port and Charging Board Replacement, Slice the remaining adhesive: passo 16, imagem 1 %32 Samsung Galaxy S22 Ultra USB-C Port and Charging Board Replacement, Slice the remaining adhesive: passo 16, imagem 2 %32
    • Slide the pick toward the bottom camera to slice through the remaining adhesive, stopping before you reach the power button.
  17. Samsung Galaxy S22 Ultra USB-C Port and Charging Board Replacement, Remove the back cover: passo 17, imagem 1 %32 Samsung Galaxy S22 Ultra USB-C Port and Charging Board Replacement, Remove the back cover: passo 17, imagem 2 %32 Samsung Galaxy S22 Ultra USB-C Port and Charging Board Replacement, Remove the back cover: passo 17, imagem 3 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • Grab and remove the back cover.
    • If your cover is still sticking to the frame, slide an opening pick around the perimeter until the cover completely separates.
    • During reassembly:
    • This is a good point to power on your phone and test all functions before sealing it up. Be sure to power your phone back down completely before you continue working.
    • Remove any adhesive chunks with a pair of tweezers or your fingers. Apply heat if you're having trouble separating the adhesive.
    • If you're using Samsung custom-cut adhesives, follow this guide.
    • If you're using double-sided tape, follow this guide.
  18. Samsung Galaxy S22 Ultra USB-C Port and Charging Board Replacement, Slice the adhesive: passo 18, imagem 1 %32 Samsung Galaxy S22 Ultra USB-C Port and Charging Board Replacement, Slice the adhesive: passo 18, imagem 2 %32 Samsung Galaxy S22 Ultra USB-C Port and Charging Board Replacement, Slice the adhesive: passo 18, imagem 3 %32
    • The wireless charging coil is lightly adhered to the battery.
    • Be careful not to strain or tear the display interconnect cable under the right side of the charging coil.
    • Insert an opening pick between the right edge of the wireless charging coil and the battery.
    • Slide the pick along the right edge to separate the adhesive.
  19. Samsung Galaxy S22 Ultra USB-C Port and Charging Board Replacement, Disconnect the NFC antenna and charging coil: passo 19, imagem 1 %32 Samsung Galaxy S22 Ultra USB-C Port and Charging Board Replacement, Disconnect the NFC antenna and charging coil: passo 19, imagem 2 %32 Samsung Galaxy S22 Ultra USB-C Port and Charging Board Replacement, Disconnect the NFC antenna and charging coil: passo 19, imagem 3 %32
    • Use the pointed end of a spudger to pry and disconnect the NFC antenna press connector from the motherboard.
    • Repeat for the wireless charging coil press connector.
    • To re-attach press connectors, carefully align and press down on one side until it clicks into place, then repeat on the other side. Don't press down on the middle. If the connector is misaligned, the pins can bend and cause permanent damage.
  20. Samsung Galaxy S22 Ultra USB-C Port and Charging Board Replacement, Identify your screws: passo 20, imagem 1 %32
    • If you're using the Samsung Self Repair Kit, take a moment to identify your screws and label them accordingly:
    • Label the bag with the most screws and the colored bag #3428.
    • If you're replacing the screen and battery, label the clear bag with two screws #3439.
  21. Samsung Galaxy S22 Ultra USB-C Port and Charging Board Replacement, Unfasten the NFC antenna and charging coil: passo 21, imagem 1 %32
    • Use your Phillips screwdriver to remove the five 3.5 mm-long screws securing the NFC antenna and charging coil.
    • If you're reassembling with the Samsung Self-Repair kit, be sure to replace the screws with the new ones labeled #3428.
  22. Samsung Galaxy S22 Ultra USB-C Port and Charging Board Replacement, Unfasten the loudspeaker: passo 22, imagem 1 %32
    • Use your Phillips screwdriver to remove the six 3.5 mm screws securing the loudspeaker.
  23. Samsung Galaxy S22 Ultra USB-C Port and Charging Board Replacement, Unclip the loudspeaker: passo 23, imagem 1 %32 Samsung Galaxy S22 Ultra USB-C Port and Charging Board Replacement, Unclip the loudspeaker: passo 23, imagem 2 %32
    • Insert the pointed end of your spudger between the upper right corner of the loudspeaker and the frame.
    • Pry up to unclip the loudspeaker from the frame.
    • Don't pry against the battery. Use protrusions in the frame for leverage.
    • During reassembly, press around the perimeter of the loudspeaker to clip it to the frame.
  24. Samsung Galaxy S22 Ultra USB-C Port and Charging Board Replacement, Remove the charging coil and loudspeaker assembly: passo 24, imagem 1 %32 Samsung Galaxy S22 Ultra USB-C Port and Charging Board Replacement, Remove the charging coil and loudspeaker assembly: passo 24, imagem 2 %32 Samsung Galaxy S22 Ultra USB-C Port and Charging Board Replacement, Remove the charging coil and loudspeaker assembly: passo 24, imagem 3 %32
    • Grab and remove the NFC, wireless charging coil, and loudspeaker from the frame.
    • The wireless charging coil holds these parts together.
  25. Samsung Galaxy S22 Ultra USB-C Port and Charging Board Replacement, Disconnect the battery: passo 25, imagem 1 %32 Samsung Galaxy S22 Ultra USB-C Port and Charging Board Replacement, Disconnect the battery: passo 25, imagem 2 %32
    • Use the pointed end of your spudger to pry up and disconnect the battery press connector.
  26. Samsung Galaxy S22 Ultra USB-C Port and Charging Board Replacement, Disconnect the interconnect cables: passo 26, imagem 1 %32 Samsung Galaxy S22 Ultra USB-C Port and Charging Board Replacement, Disconnect the interconnect cables: passo 26, imagem 2 %32 Samsung Galaxy S22 Ultra USB-C Port and Charging Board Replacement, Disconnect the interconnect cables: passo 26, imagem 3 %32
    • Use the pointed end of your spudger to pry up and disconnect the primary interconnect cable's press connector from the motherboard.
    • Repeat for the secondary interconnect cable.
  27. Samsung Galaxy S22 Ultra USB-C Port and Charging Board Replacement: passo 27, imagem 1 %32 Samsung Galaxy S22 Ultra USB-C Port and Charging Board Replacement: passo 27, imagem 2 %32 Samsung Galaxy S22 Ultra USB-C Port and Charging Board Replacement: passo 27, imagem 3 %32
    • Use the pointed end of your spudger to pry up and disconnect the primary interconnect cable's press connector from the charging board.
  28. Samsung Galaxy S22 Ultra USB-C Port and Charging Board Replacement, Remove the interconnect cables: passo 28, imagem 1 %32 Samsung Galaxy S22 Ultra USB-C Port and Charging Board Replacement, Remove the interconnect cables: passo 28, imagem 2 %32 Samsung Galaxy S22 Ultra USB-C Port and Charging Board Replacement, Remove the interconnect cables: passo 28, imagem 3 %32
    • Grab and remove the interconnect cables from the frame.
  29. Samsung Galaxy S22 Ultra USB-C Port and Charging Board Replacement, Unfasten the charging board: passo 29, imagem 1 %32
    • Use your Phillips screwdriver to remove the three 3.5 mm-long screws securing the charging board.
  30. Samsung Galaxy S22 Ultra USB-C Port and Charging Board Replacement, Pry up the charging board: passo 30, imagem 1 %32 Samsung Galaxy S22 Ultra USB-C Port and Charging Board Replacement, Pry up the charging board: passo 30, imagem 2 %32
    • Insert the pointed end of your spudger under the charging board opposite the USB-C port.
    • Pry the charging board up from its recess until you can grab it with your fingers.
  31. Samsung Galaxy S22 Ultra USB-C Port and Charging Board Replacement, Remove the charging board: passo 31, imagem 1 %32 Samsung Galaxy S22 Ultra USB-C Port and Charging Board Replacement, Remove the charging board: passo 31, imagem 2 %32 Samsung Galaxy S22 Ultra USB-C Port and Charging Board Replacement, Remove the charging board: passo 31, imagem 3 %32
    • Grip the charging board by its corners and slide it out of its recess in the frame.
    • Remove the charging board.
    • During reassembly, reinsert the charging board at a downward angle to guide the USB-C port into its recess.
Conclusão
To reassemble your device, follow the instructions in reverse order and perform the opposite actions, e.g., "reattach" instead of "removing." Skip steps that use heating and prying, and pay close attention to the 📌 bullets as you work through the steps.
After you've completed the repair, download the Samsung Members App from the Galaxy Store or the Play Store, and Samsung Self-Repair document (beginning page 10) to make sure your device is fully functional.
9 outras pessoas executaram este guia.
Clay Eickemeyer
Membro desde: 09/19/22
66.992 Reputação
Autoria de 453 guias
Equipe
iFixit Membro de iFixit
Staff
Membros da 136
Autoria de 17.301 guias
6 comentários
Do you have access to a Samsung S10 SM-G973U USB-C port charger?
FULLTILT007 - Responder
Hi! Would you be able to clarify which part you're asking about? We do sell that specific charging port, here. This replacement involves micro-soldering, and you would start at the S10 motherboard removal. If you're looking for an easier part to replace, such as the guide we are on now, we don't sell an equivalent kit for the S10.
Clay Eickemeyer -
After finishing this in about an hour, I would definitely recommend a heat gun over the Iopener. I spent around 15 minutes trying to pry the case open with the Iopener and found that it does get hot enough, but it doesn't seem to put that heat into the phone very well. I had the back cover off in around 5 minutes with a heat gun. Second, I would recommend buying the Ifixit precut adhesive seal kit, it is a few dollars, and you can be sure that you maintain the water proof seal on the phone. I did not need two of the seals, but I would have felt more secure if I had a backup in case I misaligned it and needed to start over.
Marcus Brown - Responder
I'm assuming this will also replace whatever module detects moisture?
Ian S - Responder
Most smartphones have multiple water damage indicators all around the device in the form of small non-electronic pads that discolor after exposure to water. If you're referring to an issue where persistent "Moisture Detected" type warnings are preventing you from charging your phone, then multiple causes, both software and hardware, could be factors. If, after troubleshooting, you rule out any software issues, then this repair is likely to fix a hardware or corrosion issue in your port. Good luck!
Clay Eickemeyer -
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 24
Últimos 7 dias: 226
Últimos 30 dias: 1,007
Duração total: 19,943
