Introdução
Follow this guide to remove or replace the back cover in your Samsung Galaxy S22.
Note: Retaining water resistance after the repair will depend on how well you reapply the adhesive, but your device will lose its IP (Ingress Protection) rating.
O que você precisa
Heat an iOpener and apply it to the bottom edge of the back cover for two minutes.
While you wait for the adhesive to soften, note the following:
There's adhesive securing the back cover around the perimeter of the frame.
Apply a suction handle to the back cover, as close to the bottom edge as possible.
Pull up on the suction handle with strong, steady force to create a gap between the cover and the frame.
Insert an opening pick into the gap.
Slide the pick back and forth along the bottom edge to slice through the adhesive.
Leave the pick inserted in the bottom left corner to prevent the adhesive from resealing.
Apply a heated iOpener to the left edge of the back cover for two minutes.
Insert a second opening pick at the bottom left corner.
Slide the pick to the bottom of the camera bezel to slice the left adhesive.
Leave the pick in to prevent the adhesive from resealing.
Heat an iOpener and apply it to the right edge of the back cover for two minutes.
Insert a third opening pick at the bottom right corner.
Slide the pick to the top right corner to slice the adhesive.
Leave the pick in the top right corner to prevent the adhesive from resealing.
Heat an iOpener and apply it to the top edge of the back cover for two minutes.
Insert an opening pick in the gap at the top right edge.
Slide the pick across the top edge and around the top left corner to slice the remaining adhesive.
Ferramenta utilizada neste passo:Tweezers$4.99
Grab and remove the back cover.
This is a good point to power on your phone and test all functions before sealing it up. Be sure to power your phone back down completely before you continue working.
Remove any adhesive chunks with a pair of tweezers or your fingers. Apply heat if you're having trouble separating the adhesive.
To apply new adhesive, follow this guide.
Compare your new replacement part to the original part—be sure to transfer remaining components and remove adhesive backings from the new part before installing.
6 outras pessoas executaram este guia.
