Introdução
Follow this guide to remove and replace the motherboard in the Galaxy S20 Plus.
You'll need replacement adhesive in order to complete this repair.
O que você precisa
Insert a SIM card eject tool, bit, or a straightened paperclip into the hole on the SIM tray, located at the top edge of the phone next to the plastic antenna band.
Press in firmly to eject the tray.
Heat an iOpener and apply it to the back cover's bottom edge for two minutes.
Apply a suction cup to the back of the phone, as close to the center of the bottom edge as possible.
Pull on the suction cup with strong, steady force to create a gap between the back cover and the frame.
Insert the point of an opening pick into the gap.
Apply a heated iOpener to the left edge of the back cover for two minutes.
Apply a suction cup to the back of the phone, as close to the center of the left edge as possible.
You can try also applying a few drops of high concentration (over 90%) isopropyl alcohol into the seam to help loosen the adhesive.
Apply a heated iOpener to the right edge of the back cover for two minutes.
Apply a suction cup to the back of the phone, as close to the center of the right edge as possible.
Apply a heated iOpener to the top edge of the back cover for two minutes.
Gradually slide the pick from the right edge of the device around the top right corner.
Continue slicing along the top edge all the way around to the left edge to fully separate the back cover adhesive.
Lift the back cover slowly. Use opening picks to slice any remaining adhesive.
Remove the back cover.
This is a good point to power on your phone and test all functions before sealing it up. Be sure to power your phone back down completely before you continue working.
Remove any adhesive chunks with a pair of tweezers or your fingers. Apply heat if you're having trouble separating the adhesive.
If you're using custom-cut adhesives, follow this guide.
If you're using double-sided tape, follow this guide.
Use a Phillips #00 screwdriver to remove the six 4 mm-long screws securing the motherboard bracket.
Use a pair of tweezers to gently pull up and unclip the motherboard bracket from the plastic midframe.
Use a spudger to pry up and disconnect the battery connector.
Use a spudger to pry up and disconnect the wireless charging coil connector.
Use a pair of tweezers to gently peel the wireless charging coil away from the device.
Remove the wireless charging coil.
Use a Phillips #00 screwdriver to remove the five 4 mm-long screws securing the loudspeaker and lower midframe.
Insert the point of a spudger or a pair of tweezers into the notch in the top left corner of the midframe and pry up to release the clips holding it in place.
Remove the loudspeaker and lower midframe.
Use a spudger to pry up and disconnect the main and auxiliary flex cables from the daughterboard near the bottom of the device.
Use a spudger to pry up and disconnect the main and auxiliary flex cables from the motherboard.
Gently peel up and remove the main and auxiliary flex cables.
Pry up and disconnect the left 5G antenna cable from the motherboard.
Use a spudger to pry up and disconnect the main display flex cable from the motherboard.
Gently peel up and bend the display and left 5G antenna flex cables out of the way of the motherboard and battery.
Use a Phillips #00 screwdriver to remove the three 4 mm-long screws securing the upper midframe.
Insert the point of a spudger into the notch on the right side of the upper midframe and pry up to release the clips holding it into place.
Remove the upper midframe.
Use a spudger to pry up and disconnect the right 5G antenna flex cable from the motherboard.
Use a pair of tweezers to bend the cable out of the way of the motherboard.
Pry up and disconnect the side button flex cable from the motherboard.
Bend the cable out of the way of the motherboard.
Pry up and disconnect the front facing camera flex cable from the motherboard.
Pry up and disconnect the upper 5G antenna cable from the motherboard.
Use the flat end of a spudger to pry up the corner of the 5G millimeter wave antenna module.
Remove the 5G antenna module.
Use a Phillips #00 screwdriver to remove the two screws securing the motherboard and camera assembly.
One 4 mm-long screw
One 3.4 mm-long screw
Insert the flat end of a spudger into the bottom left corner of the motherboard assembly and pry up to release it from the phone body.
Remove the motherboard assembly.
Use the flat end of a spudger to pry up and disconnect the ultrawide camera connector from the motherboard.
Remove the ultrawide camera module.
Use a spudger to pry up and disconnect the telephoto and wide-angle camera connector from the motherboard.
Pry up and disconnect the depth sensor.
Remove the remaining rear facing camera module.
After you've completed the repair, follow this guide to test your repair.
5 outras pessoas executaram este guia.
6 comentários
That is very comprehensive. Full of photos and instructions
Tarun never answered Sebastian’s questions, how much the motherboard costs… I have the same problem… got just out of the warranty, shoot.
is the internal storage actually also located on the motherboard? Means, if I change the motherboard, do I loose everything?
Hello dear
S20 plus modarbot Ned
How much price
0096896159827
