Introdução
Galaxy SII Screen Replacement Tutorial
O que você precisa
Now disconnect all connectors on the motherboard, making sure the front camera and buzzer. This is attached with the double-sided adhesive. As a precaution, remove the audio ear speaker. In all this we will always help with a plastic instrument and a spudger.
Remove with a thin tool "iSesamo" the volume rocker and power switch side, these are fixed with adhesive tape
61 outras pessoas executaram este guia.
1Comentário do guia
Hello AndreaBaglione,
We are iphone lcd dealer in China, and looking for original Iphone lcd, especially for 5G, both new and used accepted, quantity will be over 1000 and even more. Would you let me know whether you are doing this business or any channel that you can recommend? Thank you in advance. lihanshan@163.com
Best regards
Fiona
