Ir para o conteúdo principal
Samsung Galaxy R Front Facing Camera Replacement
O que você precisa
  1. Samsung Galaxy R Front Facing Camera Replacement, Rear Case: passo 1, imagem 1 %32 Samsung Galaxy R Front Facing Camera Replacement, Rear Case: passo 1, imagem 2 %32 Samsung Galaxy R Front Facing Camera Replacement, Rear Case: passo 1, imagem 3 %32
    • Insert your fingernail or a plastic tool into the opening near the headphone jack on top of the phone.
    • Gently pry apart the rear case from the midframe and remove.
    Pergunte ao FixBot
    Comentar
  2. Samsung Galaxy R Front Facing Camera Replacement, Battery: passo 2, imagem 1 %32 Samsung Galaxy R Front Facing Camera Replacement, Battery: passo 2, imagem 2 %32 Samsung Galaxy R Front Facing Camera Replacement, Battery: passo 2, imagem 3 %32
    • Insert your fingernail, or a plastic tool, into the crevice on the lower left side of the back side.
    • Gently pry the battery from the back of the phone.
    Pergunte ao FixBot
    Comentar
  3. Samsung Galaxy R Front Facing Camera Replacement, Remove screws: passo 3, imagem 1 %32 Samsung Galaxy R Front Facing Camera Replacement, Remove screws: passo 3, imagem 2 %32
    • With the Phillips head screwdriver, remove all seven 4.0 mm screws, highlighted in red, from the rear case.
    • Insert your finger or an opening tool underneath the midframe and gently pry apart from the phone.
    Pergunte ao FixBot
    Comentar
  4. Samsung Galaxy R Front Facing Camera Replacement, Front Facing Camera: passo 4, imagem 1 %32 Samsung Galaxy R Front Facing Camera Replacement, Front Facing Camera: passo 4, imagem 2 %32 Samsung Galaxy R Front Facing Camera Replacement, Front Facing Camera: passo 4, imagem 3 %32
    • The front facing camera is located in the top right corner of the back of the phone.
    • To remove the camera, gently pull until it detaches from the motherboard.
    Pergunte ao FixBot
    Comentar
Conclusão
Keon Horahan
Membro desde: 10/13/14
874 Reputação
Autoria de 6 guias
Equipe
Clemson, Team 3-3, Benson Fall 2014 Membro de Clemson, Team 3-3, Benson Fall 2014
CLEM-BENSON-F14S3G3
5 Membros
Autoria de 16 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 6
Últimos 30 dias: 29
Ao todo: 715
