Ir para o conteúdo principal
Samsung Galaxy Prime Battery Replacement
O que você precisa
  1. Samsung Galaxy Prime Battery Replacement, Battery: passo 1, imagem 1 %32
    • Insert a small spudger or fingernail into the tab that is located on the power button side of the phone and then try to pry up.
    • After the initial lift, go around the edges of the back cover lifting it up to release.
    Pergunte ao FixBot
    Comentar
  2. Samsung Galaxy Prime Battery Replacement: passo 2, imagem 1 %32
    • To remove the battery, lift up on the thumb tab located on the bottom right corner of battery bay.
    Pergunte ao FixBot
    Comentar
  3. Samsung Galaxy Prime Battery Replacement: passo 3, imagem 1 %32
    • Insert the new battery in the reverse order from taking out the battery, ensuring the metal contacts from the phone are touching the flat metal contacts on the battery. Then place another edge of battery in the bay.
    Pergunte ao FixBot
    Comentar
Conclusão
Uma outra pessoa concluiu este guia.
Equipe
UW Tacoma, Team S1-G1, Liner Summer 2018 Membro de UW Tacoma, Team S1-G1, Liner Summer 2018
UWT-LINER-SU18S1G1
5 Membros
Autoria de 8 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 14
Últimos 30 dias: 67
Ao todo: 1,985
