Esta versão pode conter edições incorretas. Mude para o último instantâneo verificado.
O que você precisa
Este passo não foi traduzido. Ajude a traduzi-lo
Switch off your phone.
Prepare an iOpener for softening the adhesive on the back of the Note8.
Apply the iOpener on the back of the Note8 along the side with the power button.
Use a suction handle to lift the back cover and create an opening pick to get in the gap.
Start at the middle of the side and cut the adhesive while pulling up with the suction handle.
Move the pick towards the bottom corner and leave it there to keep the adhesive from resealing to the case.
Use another pick and move it to the top corner.
Again take another opening pick and carefully move it around the corner and along the top edge.
Reheat with an iOpener if necessary.
Leave the pick at the top right corner to keep the adhesive from resealing.
Rotate the device and start to separate the adhesive at the bottom with another opening pick.
Leave the pick at the bottom right corner to keep the adhesive from resealing.
When the adhesive has been separated on all three sides properly you will be able to slowly lift the back cover.
Pay attention to the fingerprint sensor connector when flipping the back cover open. You might need to disconnect it as described in the next step.
Use a pair of tweezers to disconnect the fingerprint sensor.
Use an opening pick at the top edge to get between the NFC antenna and charging coil assembly and the case.
Lever the top of the assembly out of the case.
Carefully pull up the complete charging coil and NFC antenna assembly.
Use the flat end of a spudger to disconnect the battery connector.
